Go to Post Mentors can't get tired, it says so in the manual. SENIOR mentors, therefore, must have a different manual! - KathieK [more]
Unread 10-02-2007, 19:45
brennerator brennerator is offline
brennerator is an unknown quantity at this point
Rotating Servo HS322 over 90 degrees
Basically I have this servo and I want to rotate it along its entire range of motion. I have the default code, and I set pwm 11 for this servo.
if (p1_sw_trig ==1)
pwm11 = 255;
if (p1_sw_top == 1)
pwm11 = 0;
This is so that we can upshift and downshift....
Thanks.
Servo Values to Degrees... How? mogunus Programming 16 11-04-2007 02:03
How do you get servo numbers into Angle Degrees Cow Bell Solo Programming 3 18-02-2007 12:16
engineering degrees sciguy125 Career 18 17-03-2006 23:44
Turn 90 Degrees Mike Math and Science 16 05-12-2004 22:22
Rotating Light - not rotating :-/ MrB Technical Discussion 17 08-02-2002 20:36
