Go to Post FIRST is doing a great job, it's me who needs to do the hard work now. - Bomberofdoom [more]
Unread 10-02-2007, 21:21
NOV8R's Avatar
NOV8R NOV8R is offline
AKA: Chuck Brant
FRC #1583
NOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud ofNOV8R has much to be proud of
Ramp Driving Video
There was quite a bit of discussion a few weeks ago about what kind of traction KOP wheels would have on 'diamond plate'. We drove a robot on our ramp this past week and here's the video http://www.youtube.com/watch?v=qyTBvyRluOs. As you can see from the video there is more than adequate traction to slowly drive a robot up our 20 deg ramp. Since traction is coefficient of friction times normal force, robot weight is not a factor, that is if you've got enough power to do it in the first place. Btw, the ramp robot is a rookie team's that our team is mentoring
Unread 10-02-2007, 21:24
scottyh2006's Avatar
scottyh2006 scottyh2006 is offline
AKA: Elmo (and what you gonna do about it)
FRC #0564 (Ditigal Impact)
Team Role: Coach
scottyh2006 is on a distinguished road
Re: Ramp Driving Video
Is that This years Bot
Unread 10-02-2007, 21:43
Cody Carey's Avatar
Cody Carey Cody Carey is offline
AKA: C. Carey
FRC #0306 (CRT)
Cody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond repute
Send a message via AIM to Cody Carey Send a message via Yahoo to Cody Carey
And center of mass has no real bearing on traction either, unless the center of mass is arranged such that no real downward force is put on the wheels... but if that is true, you have other things to be worrying about right now.
I guess I just don't see what you were tying to say...
Unread 10-02-2007, 22:07
NOV8R's Avatar
AKA: Chuck Brant
FRC #1583
That is the robot of rookie team 2250, Lancerbotics, here in Denver. They came up with a unique design. Their concept is to be a lite robot ( it currently weighs about 30 LBS) that can drive up any ramp. Being lite they are optimistic some robot may be able to lift them with their arms. Being small their game strategy is to just drive around and get in the opposing alliances way. It looks a lot like a kitchen sink and is made out of 7075 aircraft aluminum.
Unread 12-02-2007, 20:43
lancerbotics's Avatar
lancerbotics lancerbotics is offline
FRC #2250 (Lancerbotics)
lancerbotics is an unknown quantity at this point
Thanks for the plug for our Bot. We are almost finished having just the wiring and the lid to complete. We will have pictures posted soon of our bot in its completed formation. Good luck to everyone and don't be afraid to pick-up the kitchen sink AKA "MINI-ME"
Unread 12-02-2007, 21:22
Andrew Blair's Avatar
Andrew Blair Andrew Blair is offline
SAE Formula is FIRST with Gasoline.
FRC #0306 (CRT)
Andrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond repute
Send a message via AIM to Andrew Blair Send a message via Yahoo to Andrew Blair
Err... normal force is the robot's weight. Weight has everything to do with force of friction, but, if you mean that weight has no bearing on the ability of a robot to get up a ramp, you'd be correct. Force of friction decreases linearly with weight, but so does force required to move you up the ramp.
Nice job though guys. Any issues regarding robots falling off the sides, with no guards? A bit of excitement during the matches can mean a dropped robot for teams sometimes.
Reading makes a full man, conference a ready man, and writing an exact man.
-Sir Francis Bacon
"Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius -- and a lot of courage -- to move in the opposite direction."
-Albert Einstein
Unread 12-02-2007, 21:26
Cody Carey's Avatar
AKA: C. Carey
FRC #0306 (CRT)
They should strap an inner-tube shaped construct onto their robot so that grippers have a better chance at being able to lift them.
Unread 12-02-2007, 21:42
marc marc is offline
FRC #1392 (Kinematrix)
Team Role: Leadership
marc is an unknown quantity at this point
How much clearance does a robot need to make it over the corner of your ramp onto the platform?
Unread 12-02-2007, 23:20
NOV8R's Avatar
AKA: Chuck Brant
FRC #1583
That robot has 2 1/2 inches of ground clearance on a 27 inch wheelbase. They're working on a lift fixture to try at our regional scrimage this coming weekend. Is any team thinking of trying to lift another robot with their arm?
Unread 12-02-2007, 23:54
We are in the process of installing a lift ring so that we can be lifted by robots that have a lifting arm. We should be light enough that any arm can lift us. we are guessing less than 50 pounds.
Gabe's Avatar
Gabe Gabe is offline
Pocket Full of Tools
FRC #0604 (Quixilver)
Gabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond repute
Umm... how much 7075 does this robot have?
Team site: Q U I X I L V E R
My favorite tool is my imagination; I’m always finding new ways to use it.
Unread 12-02-2007, 23:58
Lil' Lavery Lil' Lavery is offline
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Lil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond repute
Send a message via AIM to Lil' Lavery
That's still a hefty weight for most arms. Considering a game object weighs only about 1 lb. this year, most arms arn't going to be designed to lift 50.
Being correct doesn't mean you don't have to explain yourself.
Unread 13-02-2007, 16:28
edboy's Avatar
edboy edboy is offline
Plays well with others
AKA: Patrick
FRC #1261 (Robolions)
edboy is on a distinguished road
i would recommend that you put a stop on the far side of the ramp, as many robot may fall off the edge if they go too far
That match was probably one of the most amazing displays of agile mobility I have seen in a FIRST competition. We were all convinced that 1261 had
been hiding their talents up to that point, and finally decided to really show their capabilities. And when they did, was it ever impressive!
Dave Lavery
DAVE LAVERY OWNZ
Unread 13-02-2007, 23:37
WRGibbens WRGibbens is offline
Instructor Materials Fabrication
FRC #1583 (Rambotics)
Team Role: Teacher
WRGibbens will become famous soon enough
The complete tub was formed out of .050 7075 t-6 in 5 pieces with .750 Radius at the bends and it is very light assambly. The material could not be formed by conventinal process due to fracturing. We used a modified DOM process to reach the 90 deg angles without cracking.
  #15   Spotlight this post!
Unread 13-02-2007, 23:49
Team Role: Teacher
During the testing and in the video clip http://www.youtube.com/watch?v=qyTBvyRluOs we only had 2 drivers go over the edge none of them went off they just droped the wheels over the side. How ever we are going to install a angle to act as a wheel chalk to prevent over runs on the ramp it may not stop a robot at full throttle but should let the driver know there at the end of the ramp..
1583 Ramp Deployment Video NOV8R Robot Showcase 9 11-02-2007 12:09
Motor Ramp Up/Ramp Down Function Tom Bottiglieri Programming 12 03-12-2006 23:31
Video: Team 1511 Driving the Robot mpob Robot Showcase 0 16-02-2006 08:38
VIDEO: Our robot VS. the ramp Cody Carey Robot Showcase 9 09-02-2006 21:45
Ramp Riot '05 Opening Video hockeydaisy341 Off-Season Events 6 02-11-2005 14:24
