Go to Post How many of the team's current students were even alive when those awards were earned? :) - Alan Anderson [more]
  #16   Spotlight this post!
Unread 12-02-2007, 08:14
ttedrow's Avatar
ttedrow ttedrow is offline
Herding electrons
AKA: Tim Tedrow
FRC #0281 (EnTech)
Rookie Year: 2000
ttedrow will become famous soon enoughttedrow will become famous soon enough
Re: Redesign, 36mm question.
[quote=Justin M.;575913]5' long, it's rotating point is 3/4" in from the end.
You may need to read <R12>. From your description and drawing, you may be exceeding the 72" X 72" rule. This measurement does include the bumpers
Sr. Design Engineer
Caterpillar Inc.
Greenville, SC
KD4EGM
FRC 281 Greenvillains
Infected with the FIRST virus in 2000
Yes, Chute Door!!!
  #17   Spotlight this post!
Unread 12-02-2007, 08:41
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Rookie Year: 1996
As to falling arms, this is a non issue if you do the right thing and counter balance your arm.
NOTE TO EVERY TEAM WITH AN ARM:
DO YOURSELF A FAVOR -- COUNTER BALANCE YOUR ARM WITH SOME LATEX TUBE.
Seriously. This is the single best thing you can do to make your arm more controllable -- More significant than increasing your gear ratio. Really. Design in a way to wrap 20 or 30 loops of latex tube on the back side of your arm pivot and you will be much much happier. Here is a rule of thumb for you: plan on about 7lbs of force per strand of latex tube -- deciding how many loops you need is as easy as dividing by 7.
Example: Trying to hold up an arm that weighs 15lbs and has its CG at 30"? That means you need 450in-lbs (=15x30) of counter balance. If you can get a counter balance bar 6" behind the arm pivot, that means you need to pull on that bar with 75lbs (=450/6). To get 75lbs of force from latex tubing you'll need 11 strands of latex (=75/7) or 5-6 loops.
As to the 36mm gearbox, I have made a prediction about them failing with 100in-lbs of torque with repeated cycling. I predicted that the 64:1 gearboxes will fail giving situations where they see stall loads and dynamic loading. While I stick by this, the number of cycles is quite high (many hundreds in my very abusive testing).
Bottom line: Given what I know now and given good counterbalance and given that you don't make a habit of ramming your arm at high speeds into the floor or the end stops, I think that the BB 36mm gearbox could be a good choice. I would use as big of a ratio as I could in going from the gearbox to the arm (say a 96T on the arm from IFI and an 8T on the BB gearbox for a total ratio from motor to arm of 768 -- that would make your arm's freespeed be something like 20 RPM -- fast but not too fast. Using 85% per planetary stage and 95% for the chain you would have 125N-m (1100in-lbs) of torque at your arm. That would give you 22lbs at 48" -- Not too shabby. BUT don't forget that you should not design your mechanism to routinely stall these motors or they will become copper slag heaps. You should really only routinely use about 20-25% of the stall torque of these motors -- this would mean that you could only use about 5-7lbs out at the end of the arm -- not all that great -- but you could use 2 BB gearboxes and be back in business OR you could go to the 125:1 gearboxes (but I don't really like the high ratios so you have to pick your poison).
If your still nervous about the impact load replace a couple of sections of chain with spectra string (one on each side of the drive sprocket) and you'd effectively have an infinite life mechanism.
Joe J.
Joseph M. Johnson, Ph.D., P.E.
Mentor
Team #88, TJ2
  #18   Spotlight this post!
Unread 12-02-2007, 21:26
Justin M. Justin M. is offline
Mechanical/Driver
FRC #0321 (RoboLancers)
Team Role: Mechanical
Justin M. is on a distinguished road
Send a message via AIM to Justin M.
Today I replaced the 1515 with 1.25" square aluminum tubing, taking down the weight by more than 50%. We had two 60t sprockets laying around our shop so we put them on, making the ratio 11/60 - I didn't get a chance to run it yet - tomorrow we'll mount the grabber and fire it up and see how it works, and see if I'll need to make a Grainger run to get some smaller sprockets for the motors.
Thanks for your help Joe. We are running two of the 36mm 64:1 BaneBots gearboxes with the pillow blocks to power this thing.
Team 321: CHS RoboLancers - Drexel University, CHS Alumni Assn., SDP, Philadelphia Motorsports, Lima Corperation
  #19   Spotlight this post!
Unread 13-02-2007, 01:26
Dan Richardson's Avatar
Dan Richardson Dan Richardson is offline
iR3 Creative
AKA: Dan Richardson
Dan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond repute
We ordered two 10 tooth 3/8" inner bore sprockets from mcmaster for ours. Then ran them to a sponsors machine shop and begged them to place a 1/8" broach in them for us. The 6:1 is a pretty good ratio, but if your still worried about weight and lifting power put some serious consideration into using a gas strut, if only one sided arm and correct placement it can keep the arm nearly neutrally bouyant its a great great addition to any arm.
CO-Founder of Robot in 3 Days and the Robot in 3 Day Challenge.
Banebots 36mm gearbox: Recommendations for use Joe Johnson Motors 2 02-02-2007 17:10
FirstCadLibrary Updated - 36mm Gearbox Ed Sparks Inventor 2 13-01-2007 17:16
36mm BaneBots Gearmotor Model Madison Inventor 5 10-01-2007 07:35
Does anyone else forsee redesign problems? Jon K. Website Design/Showcase 2 18-12-2004 18:02
Team 121 redesign its website archiver 2000 0 23-06-2002 22:00
