Go to Post Wow, 4 pages of arguments over water...... Is it the off season or what? - Botsup [more]
Unread 11-02-2007, 10:45
robobrain0101's Avatar
robobrain0101 robobrain0101 is offline
FRC #1054 (The Knightmares)
Team Role: Leadership
robobrain0101 is an unknown quantity at this point
Send a message via AIM to robobrain0101
Last Minute Programming Failures
Does the usb-chicklet work when your robot is programmed with the default code?
Unread 11-02-2007, 10:55
esquared's Avatar
esquared esquared is offline
Keeps saying 3-2-1-Rush...
AKA: Angry Eric
no team (Volunteer!)
Team Role: Mascot
esquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond reputeesquared has a reputation beyond repute
Re: Last Minute Programming Failures
Yes.
The chicklet just makes a USB joystick look like the oldschool gameport sticks.
Unread 11-02-2007, 10:59
even though we are using a XBOX360 controller?
Unread 11-02-2007, 14:30
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
Yes. All the USB Chicklet does is map your controller's axes and buttons to the appropriate variables (p1_x, p1_y, p1_wheel, p1_aux, p1_sw_top, etc.).
Only time it gets odd is if you've picked a configuration setting such that you're using more than 4 buttons, in which case you'll need to write code to check if the most significant bits of p1_wheel and/or p1_aux are set, since this is how the chicklet encodes the higher-numbered buttons.
pic: last minute cheeseholing Veselin Kolev Robot Showcase 8 22-02-2005 19:25
A few last minute questions Jesse Control System 1 21-02-2004 19:31
Last-Minute changes? Iain McLeod General Forum 9 09-04-2003 02:51
Last Minute Mouse Robots Hamster_Power58 Rules/Strategy 1 12-03-2002 14:32
Last minute 'can we use'? Radiant Phoenix Kit & Additional Hardware 3 20-02-2002 19:02
