Go to Post Removing too much of the challenge removes too much of the accomplishment when you solve the problem. Removing too much of the challenge removes too much of the innovation in the solutions... removing too much of the challenge removes too much of the fun. - dlavery [more]
Go Back   Chief Delphi > Technical > IT / Communications > 3D Animation and Competition
Unread 11-02-2007, 11:03
supertetelmanma supertetelmanma is offline
FRC #0501
supertetelmanma is an unknown quantity at this point
Need help making water
can someone help me out with making some water , all i need to do to finish our animation is make a flowing stream of water, but i have no idea how to.... i really would apprecdiate some help!!
Unread 11-02-2007, 13:59
Mazin Mazin is offline
FRC #1720
Mazin is a name known to allMazin is a name known to allMazin is a name known to allMazin is a name known to allMazin is a name known to allMazin is a name known to all
Send a message via AIM to Mazin
Re: Need help making water
For rivers, streams, creeks, etc. you can make a plane, give it a noise displacement map, and animate the offset of the map to make it "flow."
For faucets, pouring water, etc. you can try Blobmesh, but it's tricky.
Unread 11-02-2007, 17:03
3dfernando's Avatar
3dfernando 3dfernando is offline
Pixel Transformer
AKA: Old Skull
FRC #2026 (Senai-RS)
Team Role: Animator
Rookie Year: 2007
3dfernando will become famous soon enough3dfernando will become famous soon enough
A stream of water can be made with particle flow/spray particles (if you don't know how to use particle flow)
I think you are a bit late, because you will discover that it's a lot of render time for raytraced particles... But if you want to get a good water...
Water is basically transparent, 75% refractive and 50% reflexive (we're talking about pure water)... These are the configurations you should use (well, I do use it =p) with your raytraced material. Remember that a reflexive/refractive material need an environment to reflect/refract, and if you haven't got one, you should fill the "environment" slot of your material with an HDRI map.
Then to make a flow, you need to set up a particle emitter: super spray may work, but if you want to get more flexibility, use particle flow. I recommend you to look for a tutorial with google, because I need images to get further explanation.
Good luck with it =P
Unread 11-02-2007, 19:42
FRC #1720
You didn't say anything about what kind of water you want. There are so many different ways to make water.
Help - Making the autonomous mode razer Programming 5 31-01-2007 16:25
Need Help Making Part from Spec Goaliexam Inventor 10 26-07-2006 11:34
HELP!!!!!! LABVIEW IS MAKING ME MAD!!!! cdennisxlx2 LabView and Data Acquisition 2 21-03-2006 21:50
Making a Dongle - Pin 1 help DanL Electrical 6 05-03-2003 16:58
I need help w/ making an Invitational Matt Attallah General Forum 6 14-05-2002 19:48
