Go to Post I think with so many facets of FIRST, success comes from learning the true meaning of teamwork through working towards a common goal. - Kristina [more]
Unread 11-02-2007, 21:10
Ryan Lynam Ryan Lynam is offline
FRC #0296
Ryan Lynam is an unknown quantity at this point
aircraft flooring
We have been given a few sheets of aircraft flooring from Bombardier and Air Canada (our sponors) and we are considering using it for our ramp and end-game device. It is a composite honeycomb that is sandwiched with carbon fibre on one sheet and aluminum on another. We have very little knowledge of this material and whether it will be permitted in our final robot construction. Has anyone ever worked with this stuff? Will there be any problems using it on our robot? We can certainly tell you that it is really light and strong, but we have no idea how to come up with a price value for it.
Thanks.
Ryan
Unread 11-02-2007, 21:14
ebmonon36's Avatar
ebmonon36 ebmonon36 is offline
AKA: Eric Bredehoeft
FRC #1018 (Robodevils)
ebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud of
Send a message via AIM to ebmonon36
Re: aircraft flooring
We have used it on our robots for the last 3 years, and will also be used on this year's robot. It is a fairly easy material to work with and yes, very strong. There should be a picture showing up soon from our team with an example of what we are using it for this year. As for price, I'm not exactly sure how much it runs for.
Eric
Unread 11-02-2007, 21:17
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Ryan,
As long as it is allowed under the flowchart and does not contain hazardous materials, it should be allowed. When in doubt ask the Q&A but if it is allowed, you must come up with a price. If you are claiming a COTS item (which I think you would) it has to be available to to other teams and the price they would pay is the price you must enter in your BOM.
I can't wait to see your ramp!
Al
WB9UVJ
www.wildstang.org
________________________
Unread 11-02-2007, 21:16
Rohith Surampudi's Avatar
Rohith Surampudi Rohith Surampudi is offline
probably needs a new WAI
FRC #0075 (RoboRaiders)
Rohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond repute
Send a message via AIM to Rohith Surampudi
Thanks.
Ryan
the material you speak of is from what i understand very popular this year, and is infact permitted, from the information you provided i cant tell much, however composite honeycomb sheets are generally much stronger than plywood, and used in many applications, however their strength depends on the inner capsules as well as the width of the plastic coating on the outside, more info can be found on the website www.nida-core.com , i have seen many samples of this material, it is very light, as well as very hard, seeing as it is the grade used for airplane flooring, id assume its upward of 120lb per square foot, however be sure to look through the data and specifics on the nidacore website, some truss-work may be required to re-enforce the sheet, the material is very very reliable.
good luck,
rohith
Blargha!
Unread 11-02-2007, 22:02
Bill_Hancoc's Avatar
Bill_Hancoc Bill_Hancoc is offline
Volkswagen Enthusiast
AKA: Bill Hancock
FRC #0573 (MechWarriors)
Team Role: Mechanical
Bill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud of
Send a message via AIM to Bill_Hancoc
just a heads up the link for the nida core website is www.nida-core.com
MechWarriors 573
Unread 16-02-2007, 20:09
Gary Dillard's Avatar Unsung FIRST Hero
Gary Dillard Gary Dillard is offline
Generator of Entropy
AKA: you know, the old bald guy
FRC #2973 (The Mad Rockers)
Rookie Year: 1998
Gary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond repute
Send a message via AIM to Gary Dillard
We are using a similar material, scrap that was donated to us by Pratt & Whitney, COTS material made by Hexcel. It is 1 inch thick aluminum honeycomb with 18oz cloth face sheets. The raw material price that they paid was $1100 for a 4 x 7 sheet, which is what I'm using for our cost basis. The largest single component we are using is a 28 x 36 piece which prices out at about $275 - less than the $400 allowable.
I spoke with the engineers at Nida-Core (they are about an hour north of us) and they have a similar material; It is COTS - the core is stocked but laminated sheets are not normally stocked. They have about a 2 week turnaround to laminate it so it's well within the guidelines. They also said they have been bombarded with calls from FIRST teams.
Close enough to taste it, too far to reach it
pic: 498's Aircraft Carrier Donut Extra Discussion 8 21-01-2007 21:35
pic: 498's Aircraft Carrier Deployed Donut Extra Discussion 18 19-01-2007 15:03
A very cool movie for download (aircraft) Frank(Aflak) Chit-Chat 4 07-06-2004 23:56
