Go to Post Blowing out the transmission on your mini-van while hauling a trailer 700 miles from home is not fun. Trust me on this. - dlavery [more]
Unread 12-02-2007, 07:58
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
Team Role: Coach
Doug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond repute
Compressor fuse keeps blowing
The SPIKE relay fuse that runs our compressor keeps blowing out when the tank pressure gets up to 120. We're worried there's a problem with our compressor. We have checked that it is running with +12V on the red lead and the pressure switch is turning off our compressor (through software) at 120 psi. I just dont get what else may be the problem. Our next fix will be to replace the pump with last years. Any other ideas??
Work Hard, Have Fun, Make a Difference!
Unread 12-02-2007, 08:05
artdutra04's Avatar
artdutra04 artdutra04 is offline
VEX Robotics Engineer
AKA: Arthur Dutra IV; NERD #18
FRC #0148 (Robowranglers)
artdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond repute
Re: Compressor fuse keeps blowing
Check your main robot battery. As the voltage of your main robot battery decreases, the amperage of the current traveling to all your electrical loads will increase. (E.g. Watts = Volts x Amps). This increased amperage is usually what blows the fuse on the Spike relay.
Replacing your main robot battery with a fresh one should take care of most of your issues.
Edit: Oops, I forgot Ohm's Law.
Art Dutra IV
Robotics Engineer, VEX Robotics, Inc., a subsidiary of Innovation First International (IFI)
Robowranglers Team 148 | GUS Robotics Team 228 (Alumni) | Rho Beta Epsilon (Alumni) | @arthurdutra
世上无难事,只怕有心人.
Unread 12-02-2007, 08:30
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Doug,
This occurs due to the high starting current of the pump, up to about 25 amps. The rules state that for the pump Spike only, you may replace the 20 amp fuse with a 20 amp snap action breaker. All should be better.
Art,
Your amps vs. volts would hold true with certain types of power supply but not with the battery. What does occur as the current increases is that the terminal voltage drops. This is due to simple Ohm's Law V=I*R, for the internal resistance of the battery which is 0.011 ohms. At 100 amps this translates to 1.1 volt drop in the terminal voltage.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 12-02-2007, 09:04
N7UJJ N7UJJ is offline
Teacher
AKA: Allan Cameron
FRC #5465 (BinaryBots)
Team Role: Teacher
N7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond reputeN7UJJ has a reputation beyond repute
Not correct. As the voltage of the battery drops, the current will drop also.
Ohm's law: current = voltage/resistance. As voltage decreases, current decreases proportionally. (half the voltage, half the current)
As voltage and current decrease, power (watts) decrease dramatically. Thus half the voltage, which results in half the current, means the power is one fourth of what it was.
Unread 19-02-2007, 00:03
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
Is the relief valve installed?
Most of the pressure switches I have seen cut off the compressor at 115 (or less) - if you are actually getting to 120 psi you may not actually be turning off the compressor and it is overloading at 120 and blowing the fuse.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 20-02-2007, 05:13
Barak Shelef's Avatar
Barak Shelef Barak Shelef is offline
FRC #3316 (D-Bug)
Rookie Year: 2007
Barak Shelef will become famous soon enoughBarak Shelef will become famous soon enough
We have the same problem.
So can we use a snap breaker?
Other then avoiding the problem, Is there another way of solving the problem permenently?
thnx,
Barak Shelef
team#2230
Handasaim High-School, Israel.
Unread 20-02-2007, 06:20
Unsung FIRST Hero
Mike Betts Mike Betts is offline
Electrical Engineer
Rookie Year: 1995
Mike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond repute
thnx,
Barak Shelef
team#2230
Barak, at al,
<R65> The control system is provided to allow wireless control of the ROBOTS. The Operator Interface, Robot Controller, speed controllers, relay modules, radio modems, batteries, battery charger, AC adapter, and 9-pin cables can not be tampered with, modified, or adjusted in any way, (tampering includes drilling, cutting, machining, gluing, rewiring, etc.) with the following exceptions:
• Dip switches on the Operator Interface may be set as appropriate.
• User programmable code in the Robot Controller may be customized.
• Speed controllers may be calibrated as described in owner's manuals.
• The fuse on the Spike relay for the air compressor may be replaced with a 20 Amp Snap-Action circuit breaker.
The last bullet of <R65> is very clear and does solve the problem permanently.
Mike
Mike Betts
Alumnus, Team 3518, Panthrobots, 2011
Alumnus, Team 177, Bobcat Robotics, 1995 - 2010
LRI, Connecticut Regional, 2007-2010
LRI, WPI Regional, 2009 - 2010
RI, South Florida Regional, 2012 - 2013
As easy as 355/113...
Unread 20-02-2007, 06:32
FRC #3316 (D-Bug)
Rookie Year: 2007
Originally Posted by Mike Betts View Post
Barak, at al,
Mike
awesome, our Pneumatics team must have missed that.
Thanks, mike.
Running just the compressor (was: free compressor) sciguy125 Pneumatics 15 06-02-2006 18:23
Labview keeps freezing SHerpich LabView and Data Acquisition 31 02-02-2006 14:53
picture of 40 amps fuse holder and fuse rcubes85 Technical Discussion 1 13-02-2003 16:03
Time keeps on ticking /)/)/) archiver 2001 2 23-06-2002 22:12
Blowing 60 Amp fuse archiver 1999 4 23-06-2002 22:07
