Need to Find Specific Sprocket! Help!
I'm trying to find a sprocket that fits the following dimesions: Outer diameter of 3.553 inches, Pitch Diameter of 3.349 with 28 teeth and fits a chain size of 35. We found a few sites however we need shipped here by wednesday! We have the FIRST sprockets however we don't want to use them. We need something a little thicker. Any help is appreciated
Re: Need to Find Specific Sprocket! Help!
What type of hub should it have? or is it hubless, with a hole of some size in the center?
There are many places that sell sprockets, but which one is best depends on how you plan to mount the sprocket. |
Martin Sprocket : http://www.martinsprocket.com/sprockets.htm
If they don't have what you want, it doesn't exist. |
Not by wednesday, though. I highly recommend just finding something that will work for you at McMaster-Carr or SDP-SI. Either are highly likely to have what you need, and more importantly will ship same day if you hurry and can ship overnight.
Try Grainger. You can use will call and pick up your order at your local branch that same day, if they have everything in stock. If they don't, they can get it and you can pick the stuff up the next day. The only issue is you need an account, they are wholesale only. You can set up an account at your local branch, or call them. They're really good with shipping as well, but the best part is the fact they have a ton of local branches.
Other than that, if we put an order in with McMaster before 3, we get it next day with normal shipping (since their warehouse is in NJ). |
For hubless, try AndyMark.biz (they have hubs for it, too). We've been happy with their products, and they make a 28T #35 sprocket. See here:
http://andymark.biz/35sealsp.html - Keith McClary Chief Engineer, Team 1502 "Technical Difficulties" |
| Need help with locking on sprocket | Shaggy9356 | Kit & Additional Hardware | 6 | 18-01-2007 22:25 |
| Stuck sprocket - need advice | sanddrag | Technical Discussion | 20 | 13-10-2005 12:12 |
| sprocket help | katkana | Technical Discussion | 7 | 21-02-2005 17:23 |
| Need to find 5/8" sprocket | hedgehogger | Kit & Additional Hardware | 3 | 14-02-2004 09:23 |
| Gear/Sprocket Help | Joseph F | Motors | 3 | 18-03-2002 07:48 |
