Go to Post Titanium is almost twice as heavy as aluminum. I can have the bragging aspect of making a bullet resistant robot, but if someone is coming into a competition and shooting my robot, I have more important things to worry about! - Andrew Blair [more]
Unread 12-02-2007, 13:53
Kevin Watson's Avatar
Kevin Watson Kevin Watson is offline
La Caņada High School
FRC #2429
Kevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond repute
Camera Code Update
I've made a few changes to the camera code and would like to get some feedback before releasing it. If you can think of something you'd like changed or added, please leave a message here. These are the changes do far:
2/11/07 changes made for version 2.2:
Important: after loading the new software, make sure
you "Load default values" and then "Save changes" from
the tracking menu.
terminal.c/.h:
-Fixed benign bug where old_camera_t_packets was not getting updated in Tracking_Info_Terminal().
-Altered code to use Tracking_Config_Data values for center tilt and pan values instead of hardwired values in Tracking_Info_Terminal().
-Altered code to use Get_Camera_T_Packets() function instead of directly accessing camera_t_packets variable.
camera.c/.h:
-Added Poll_Mode() function.
-Added Get_Camera_ACKs() function.
-Added Get_Camera_NCKs() function.
-Added Get_Camera_T_Packets() function.
tracking.c/.h:
-Changed default CONFIDENCE_THRESHOLD_DEFAULT values to 10 (was 20).
-Greatly simplified search code (same functionality with less code).
-Changed search parameters so that a fixed tilt angle of about 30 degrees is used.
-For finer control, moved camera pan servo to PWM output 15.
-For finer control, Moved camera tilt servo to PWM output 16.
user_routines_fast.c:
-Replaced call to Generate_Pwms() in User_Autonomous_Code() with a call to PWM().
serial_ports_readme.txt:
-Corrected installation instruction #4.
camera_readme.txt:
-Added Virtual_Window() function description.
-Added Poll_Mode() function description.
-Added Get_Camera_ACKs() function description.
-Added Get_Camera_NCKs() function description.
-Added Get_Camera_T_Packets() function description.
pwm.h:
-Using new PWM() software, optimized camera tilt for a range of 0 to 90 degrees.
-Kevin
Kevin Watson
Engineer at stealth-mode startup
http://kevin.org
Problems Combining Camera Code and Driving Code cmurdoch Programming 20 10-02-2007 16:34
Problems when combine ADC code && camera code nirhaim1942 Programming 1 24-01-2007 06:58
problems using gyro/adc code with camera default code tanstaafl Programming 7 22-01-2006 23:09
Code error on RC after downloading "bells and whistles" version of Kevins camera code DanDon Programming 6 10-01-2006 18:07
Team THRUST - Kevin's Code and Camera Code Combine Chris_Elston Programming 3 31-01-2005 22:28
