Go to Post Support an awesome scholarship fund for deserving students by buying sweet CAH expansion packs? Heck yeah. - Cothron Theiss [more]
Unread 12-02-2007, 14:09
benhulett benhulett is offline
FRC #1895
benhulett is on a distinguished road
Incrementation Code not working
We were working on our Incrementation code for our control system, it just makes sure we dont' make abrupt changes in our movements that could damage something....we had it working for the Y coordinates, but then we incorporated it into a function so both Y and X could call on it. That's where everything went wrong....The servos we were testing with would move in random directions without us controlling. Here is the code we wrote:
Code:
int Incrementation_Code(int motor_curr, int motor_prev, int padd, int max_step)
  int change = 0;
  int RetVal;
  change = motor_curr - motor_prev;
  if (change >= padd)
    //Accelerate
	if (change > max_step)
      RetVal = motor_prev + max_step;
      printf("Motor accelerated by MAX = %d.  ", max_step);
    else
      printf("Motor accelerated by %d.  ", change);
	if ( RetVal > 255 )
      RetVal = 255;
      printf("Detected excess of 255!  ");
  else if (change <= -padd)
    //Decelerate
    if (change < -max_step)
      RetVal = motor_prev - max_step;
      printf("Motor decelerated by MAX = %d.  ", max_step);
    else
      printf("Motor decelerated by %d.  ", change);
    if (RetVal < 0)
      RetVal = 0;
      printf("Detected below-zero condition!  ");
  else
    //no change
    RetVal = motor_prev;
	printf("No change in motor output value.  ");
  printf("\r\n");
  return RetVal;
int last_p1x_val=128;
int last_p1y_val=128;
void Default_Routine(void)
	int maximum_step=10;
	int padding=3;
 /*---------- Analog Inputs (Joysticks) to PWM Outputs-----------------------
  *   This maps the joystick axes to specific PWM outputs.    */
  p1_y = Incrementation_Code(p1_y, last_p1y_val, padding, maximum_step);
  last_p1y_val = p1_y;
  pwm01 = p1_y;
  pwm02 = p2_y;
  pwm03 = p3_y;
  pwm04 = p4_y;
  p1_x = Incrementation_Code(p1_x, last_p1x_val, padding, maximum_step);
  last_p1x_val = p1_x;
  pwm05 = p1_x;
  pwm06 = p2_x;
  pwm07 = p3_x;
  pwm08 = p4_x;
  pwm09 = p1_wheel;
  pwm10 = p2_wheel;
  pwm11 = p3_wheel;
  pwm12 = p4_wheel;
Unread 12-02-2007, 14:21
EHaskins EHaskins is offline
Needs to change his user title.
AKA: Eric Haskins
no team (CARD #6 (SCOE))
EHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond repute
Send a message via MSN to EHaskins
Re: Incrementation Code not working
Do both servos move erratically, or only the X servo?
Did you change the Incrementation_Code function?
If you have a copy that worked with only one servo try changing it so it uses the other servo/input.
I will test the code tonight, and see if I can find the problem.
Eric Haskins KC9JVH
Unread 12-02-2007, 14:24
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
You don't set RetVal in all branches of your function.
Unread 12-02-2007, 14:29
AKA: Eric Haskins
Joe Ross is right.
Code:
    //Accelerate
    else
      RetVal = motor_prev + change;
    //Decelerate
    else
      RetVal = motor_prev - change;
Eric Haskins KC9JVH
Unread 12-02-2007, 14:33
FRC #1895
Originally Posted by EHaskins
Joe Ross is right.
Code:
//Accelerate
    else
    //Decelerate
    else
I can't believe we didn't notice that Thanks for the help! I'll be sure to test that when I get the chance tonight.
Unread 12-02-2007, 14:46
AKA: Eric Haskins
Good luck.
Eric Haskins KC9JVH
Unread 12-02-2007, 17:39
FRC #1895
It works fine!! The only difference than what you provided in the code was to assign it the motor_curr rather than adding or subtracting the change.
Subscriptions not working? Jeff Waegelin CD Forum Support 2 07-02-2007 14:11
easyc demo code not working sniggel Programming 5 28-01-2007 16:40
2007 demo code not working thefro526 Programming 4 12-01-2007 23:43
Camera code not working.... DemonYawgmoth Programming 5 11-02-2006 09:21
heres the code. y this not working omega Programming 16 31-03-2004 15:18
