Go to Post The longer you play robots, the more you realize that it's not about the robots. - dtengineering [more]
  #16   Spotlight this post!
Unread 14-02-2007, 14:20
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
Re: Dropping Ramp Issues
Originally Posted by Bill_Hancoc View Post
If you had a spring could you maybe put it somesort of mechanical lock on the ramp so that i cannon deploy until you disengage it. Maybe power it with a servo or something small. This way if you are concerned that it will deply accidentally there is always a good mechanical lock preventing it then you can still keep you current piston mount.
Thirded. Use springs that are strong enough to knock your ramp over and change the function of your piston to disengage a latch. We're doing something similar, though we're using our ramp lifting motors to disengage the retaining system. The retaining system is still to be defined, but at worst we'll be using highly calibrated fishing line to tie the ramps together and just break it with our ramp motors.
  #17   Spotlight this post!
Unread 14-02-2007, 16:32
Mike Martus's Avatar Unsung FIRST Hero
Mike Martus Mike Martus is offline
FRC #0051 (Wings of Fire)
Team Role: Coach
Rookie Year: 1996
Mike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond repute
Originally Posted by techknow 1685 View Post
Hello,
I just registered to cheif delphi, so i am new at using this site.
I hope i am doing this right.
Anyway, does anybody know what kind of what kind of motors can we use for the robot?
Can we use a motor from power drill?
Please read ALL the 2007 rules very carefully. There are limitations and restrictions on many things including motors and wire used.
To answer your question NO you may not use any motor that was not either provided in the kit of parts or is on a approved additional motor (quanity) list. All of this is very clear in the 2007 manual. FIRST did a very good job this year with this document.
Mike Martus
  #18   Spotlight this post!
Unread 14-02-2007, 20:00
bsbllpss's Avatar
bsbllpss bsbllpss is offline
[RockStar]
AKA: RJ
FRC #2044 (Big Red Robotics)
Team Role: Electrical
Rookie Year: 2007
bsbllpss is an unknown quantity at this point
Send a message via AIM to bsbllpss
springs are stored energy otherwise illegal
newbs
  #19   Spotlight this post!
Unread 14-02-2007, 20:12
Mister_Juggles's Avatar
Mister_Juggles Mister_Juggles is offline
The good-looking one.
AKA: Joey
FRC #0422 (Green Dragons (under review))
Team Role: Leadership
Mister_Juggles is just really niceMister_Juggles is just really niceMister_Juggles is just really niceMister_Juggles is just really niceMister_Juggles is just really nice
Send a message via AIM to Mister_Juggles
You could always have the pin/lock idea (where the piston pulls away something blocking the ramp from falling) and just spin your bot in the home zone. As long as your bot can spin in a somewhat small circle, then you might be able to pull it off.
"Who do you want to be remembered as the greatest horn player ever, you or some felonious monk?" --Terry Pratchett
http://xkcd.com/c246.html
http://xkcd.com/c123.html
<G09> Dropping Tubes on Your Opponent Jimmy Cao Rules/Strategy 43 10-01-2007 12:26
Dropping a Regional w_b305 Regional Competitions 1 13-01-2005 09:51
dropping balls Joe Ross Math and Science 18 25-08-2004 22:40
Dropping attachments? Tom Bottiglieri Rules/Strategy 4 13-01-2004 11:24
Dropping extra regionals for new rookies... dez250 General Forum 13 13-11-2003 14:20
