Location of solid state relay
For the diagnostic light, where do I mount the solid state relay? Also, the diagnostic light, it looks like it is supposed to be screwed on to something? Where?
Re: Location of solid state relay
The relay is meant to go on a DIN rail, so you may want to put it with the power distribution blocks. The light can go anywhere you choose, so long as you adhere to <R16>.
thanks. how do we mount the diagnostic light? it has ridges that looks like it is supposed to be screwed on to something, but what?
There should be a nut on the threads already. Check the tips and good pratices for the size of the hole, or just measure it.
| Solid core inductance | [527]phil | Electrical | 26 | 05-11-2006 17:01 |
| is it a solid or a fluid? | John Gutmann | Technical Discussion | 11 | 05-08-2005 01:05 |
| Solid wingman | nuggetsyl | General Forum | 0 | 05-04-2004 10:48 |
| solid edge solid works | ceileachair | Inventor | 1 | 21-01-2003 22:03 |
| Solid Works | 157#1Driver | Inventor | 0 | 21-04-2002 20:17 |
