Go to Post Each match is a learning experiance - the only thing you can do is get better. - SuperJake [more]
Unread 12-02-2007, 17:42
Brigander's Avatar
Brigander Brigander is offline
Website Wizard
AKA: Andrew Roberge
FRC #1723 (F.B.I)
Rookie Year: 2007
Brigander is an unknown quantity at this point
Exclamation Programming a Solenoid
How does one go about controlling a soleniod with the program? I have looked everywhere i could think of and found nothing on this topic.
Only those who do not try are doomed to fail.
Unread 12-02-2007, 18:14
Travis Hoffman's Avatar Unsung FIRST Hero
Travis Hoffman Travis Hoffman is offline
O-H
FRC #0048 (Delphi E.L.I.T.E.)
Travis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond reputeTravis Hoffman has a reputation beyond repute
Re: Programming a Solenoid
http://www.chiefdelphi.com/forums/sh...58&postcount=3
Travis Hoffman, Enginerd, FRC Team 48 Delphi E.L.I.T.E.
Encouraging Learning in Technology and Engineering - www.delphielite.com
NEOFRA - Northeast Ohio FIRST Robotics Alliance - www.neofra.com
NEOFRA / Delphi E.L.I.T.E. FLL Regional Partner
Unread 14-02-2007, 21:08
seanl's Avatar
seanl seanl is offline
"The Everything person"
FRC #0867 (Absolute Value)
Team Role: Leadership
Rookie Year: 2007
seanl will become famous soon enoughseanl will become famous soon enough
you could hook it up to a relay and plug it in to any relay port but if you are using the default code you could use relay port 1 or 2 they are already mapped to the triggers on the 2 joysticks
Unread 15-02-2007, 18:15
Brigander's Avatar
Website Wizard
AKA: Andrew Roberge
FRC #1723 (F.B.I)
Rookie Year: 2007
thank you for the help
Unread 17-02-2007, 14:06
jaker29902 jaker29902 is offline
FRC #2092
jaker29902 is an unknown quantity at this point
I got this to work with EasyC pretty easily once I figured it out.
The best way I've found to do it (with EasyC) is to wire the solenoid to a spike relay, (if you need help wiring look somewhere on this forum) and then grab a OI to Relay function block in easy and plug in the correct values, quick and easy have ours set to trigger for forward/extend and thumb for backwards/retract. Just tap the button and off it goes, once we got the wiring schematic and I fugured out the programming took us about...oh..ten minutes to get it set up and maybe another 20-30mins to actually mount it.
Pneumatics (Spike Relay, Solenoid etc.) Programming oceansidehs Programming 8 10-02-2007 13:58
Solenoid control Grizzlie Programming 4 16-02-2005 17:35
Solenoid Programming duckshepherd Pneumatics 1 17-02-2003 09:15
Fresno solenoid.... mike325 Technical Discussion 3 11-02-2003 07:50
Solenoid Wires archiver 2001 2 24-06-2002 00:56
