Solenoid Help
How do I Program A Soleniod to work with a vacuum system? I need to be able to control the vacuum system with a button on the joystick and have no clue to go about starting this process.
Re: Solenoid Help
you need to open up user routines.c
and go down to where it maps the relays to the joystick buttons. and change what ever you need to change. if you want to use the triggers i think relay 1 and 2 are mapped in the default code already. hope this was helpful. |
Re: Solenoid Help
Try easyC if you have a hard time programming with MPLAB. It will most likely make this much easier for you.
| Help with the SMC SOlenoid | FRC1710 | Pneumatics | 5 | 13-02-2007 13:22 |
| Help with double solenoid | almsfan21 | Pneumatics | 2 | 30-01-2007 19:57 |
| Gunk in solenoid | Nitroxextreme | Pneumatics | 3 | 22-02-2005 07:24 |
| Double Solenoid Help | doyler | Programming | 4 | 19-02-2005 11:36 |
| 24 Volt Solenoid? | Stephen Kowski | Pneumatics | 2 | 27-01-2005 11:44 |
