Go to Post I put the encrypted manual file onto a 5-1/4" floppy disk, so I'll have it with me when I go to the kickoff event and pick up the kit. - MrForbes [more]
Unread 12-02-2007, 17:51
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
Team Role: Coach
Doug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond reputeDoug G has a reputation beyond repute
pic: 701's Glowing Operator Interface
Unread 12-02-2007, 17:56
robostangs548's Avatar
robostangs548 robostangs548 is offline
Team 548 General Motors Robostangs
AKA: Mason Falk
FRC #0548 (General Motors Robostangs)
Rookie Year: 1999
robostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant future
Send a message via AIM to robostangs548
Re: pic: 701's Glowing Operator Interface
We were thinking of doing this, but I think that there is something somewhere in the rules that says that you can't. I am not 100% sure, but I know that we were going to but we ended up not because of a "illuminated lighting" problem. If you get a chance I would check out the rules in the FRC manual, because I would be extremely unfortunate if you got to the competition and couldn't use this great achievement of design. But other then that minor rule, I think that your board is sweet, and great job on it.
Unread 12-02-2007, 18:24
Dave Flowerday Dave Flowerday is offline
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Dave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond repute
Normally, lights on the OI shouldn't be a problem as long as they have a separate battery pack and aren't connected to the joystick ports somehow. However, I could see inspectors taking issue with your use of neon green lights, specifically as a violation of R33:
<R33> No devices or decorations are permitted on the ROBOT that are intended to jam or interfere with the operation of the vision system (i.e. changing ROBOT color to confuse opponent’s vision system).
(Remember, other rules make it clear that the OI is considered part of the ROBOT and therefore this rule does apply).
As an additional note, I'd advise turning off any neon lights during the match. We had neon on our operator console back in 2002 (and 2003?) and we saw problems with the radio link while they were on. We put a switch on ours so that the drivers could turn them off before the match began.
Unread 14-02-2007, 03:47
Doug G's Avatar
Coach / Teacher
Team Role: Coach
The lights are powered up separately and we just won't run them when on the field to play it safe. Pretty much for aethetics off the field anyways.
Work Hard, Have Fun, Make a Difference!
pic: FRC488 - Operator Interface Madison Extra Discussion 6 17-02-2007 04:45
pic: Team 369: Operator Interface Gabriel Mendez Extra Discussion 4 12-02-2007 22:06
pic: operator interface cad Daniel367 Extra Discussion 2 15-01-2007 16:33
pic: Team 228 Operator Interface artdutra04 Robot Showcase 7 11-03-2005 21:41
pic: Portable Power Pack for Operator Interface CD47-Bot Extra Discussion 13 19-07-2004 03:02
