Go to Post Chief Delphi isn't for making enemies...it's for making friends. - Alex Pelan [more]
Unread 12-02-2007, 22:56
Ianuser Ianuser is offline
FRC #0570
Ianuser is an unknown quantity at this point
I'm having trouble with this camera stuff
Ok, I want to make a button turn off the camera and then the same button turn on the camera. THis is what I have. (This is in the Default_Routine())
Code:
             int now4; //for mapping p3_sw_aux2 to ON or OFF (reset CAMERA)
	int last4;	//for mapping p3_sw_aux2 to ON or OFF (reset CAMERA)
	last4 = now4;
	now3 = p3_sw_aux2;
some joystick stuff...then..
Code:
if((Get_Camera_State() == 0) && (now4 == 1) && (last4 == 0))
   	  Restart_Camera(); //Sets Camera in Recieving Mode so it can be used.
  if((Get_Camera_State() == 1) && (now4 == 1) && (last4 == 0))
	  Camera_Idle(); //Sets Camera in OFF Mode in case we need to stop chasing the light and go into manual mode to go back to home base or something
Will Camera_Idle() stop the Camera from functioning so the robot will no longer track the light? It does, right? Cuz it stops the initialization of it. So, doesn't Restart_Camera() do the opposite of Camera_Idle()? If not, please tell me if there's a way in which I can do this? Maybe I'm mapping the button incorrectly, but its not working, I know that.
p.s. The camera works fine (sorta, thats another story though), it just doesn't stop searching when I press the button. I want it to stop searching when I press the button.
Unread 12-02-2007, 23:35
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: I'm having trouble with this camera stuff
If you want the camera to stop searching, just stop calling Servo_Track().
Unread 13-02-2007, 04:08
Bomberofdoom's Avatar
Bomberofdoom Bomberofdoom is offline
Biggest FIRST addict in Israel
AKA: Nir Levanon
FRC #2230 (Zcharia's Angels)
Rookie Year: 2007
Bomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond repute
Send a message via MSN to Bomberofdoom
How exactly do you stop calling a function? Unless you use an if code to define that once something happens, move on with the code, not going over Servo_Track() again, how can you stop calling it?
Unread 13-02-2007, 09:42
Software Architect
That is exactly how you do it.
Code:
  if(I_want_to_search)
    Servo_Track();
Just make "I_want_to_search" true to begin with, and make it false when you don't want to call Servo_Track() anymore.
Unread 13-02-2007, 10:28
Tom Bottiglieri Tom Bottiglieri is offline
FRC #0254 (The Cheesy Poofs)
Tom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond repute
When the camera has a green color blob in its view, it sends T packets over the serial port to the RC.
Servo_track() looks to see if there are new t packets in the input buffer. If there are, the RC knows that the camera sees a color blob and locks on to it. If there are no new t packets, the camera will go into its search routine (as it does not see any color blobs..)
Camera_Idle() writes a "\r" to the camera serial port. This tells the camera to stop what its doing, and to stop sending t packets.
Restart_camera() simply sets an initialization flag to 0, so when the Initialize_Camera() function is called, it will return all of the internal workings of the camera back to their default (this is probably for users who want to mess around with polling mode, virtual windows, gains, etc..)
The problem you are having is you are Initializing the camera (default in user_routines.c from the camera workspace), stopping the camera from sending t packets, and then clearing the init flag. You are never telling the camera to turn back on. You can do this in one of two ways.
A) Call Initialize_Camera() again.
B) Call Track_Color() with the default stuff as arguments.
I would do the latter as re-initializing the camera will cause it to go through a bunch of code that isnt going to do anything. Also, you don't need to call Reset_Camera() ever.
Unread 13-02-2007, 10:45
Bharat Nain's Avatar
Bharat Nain Bharat Nain is offline
Bharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond repute
Send a message via AIM to Bharat Nain Send a message via MSN to Bharat Nain
Code:
if(p3_sw_top)
          Servo_Track();
else
          (Whatever, set servos to 127 or something)
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Having trouble with your camera mount? Chriszuma Programming 7 01-02-2005 22:12
Anyone else having trouble keeping up with work? D. Gregory General Forum 36 28-03-2004 16:55
Having trouble with TTL port Gene F Programming 12 10-02-2004 15:23
Im am having trouble with the MPLAB hedgehogger Programming 7 19-01-2004 17:37
I'm having trouble sleeping!! archiver 1999 5 23-06-2002 22:38
