Go to Post Aha I just noticed you're from my team. --Petey - Petey [more]
Unread 13-02-2007, 14:48
Zero_Cool Zero_Cool is offline
FRC #1208
Zero_Cool is an unknown quantity at this point
Question Tracking_state confusion
I have already written a working autonomous code with my team's robot, but I have a small problem that keeps occuring. Our robot will see the light and then a leg of the spider will obstruct the view of the camera, completely eclipsing the light. And if the camera is searching and can not find the light it will use those values and go into destroy mode killing everything around it. How can I use the tracking_state to stop the robot from moving if it doesn't see the light or if it has lost the light? I honestly do not understand the many states of this camera.
Unread 13-02-2007, 14:58
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Rookie Year: 2000
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
Re: Tracking_state confusion
One approach would be to keep track of your heading, independent of the camera. If you loose tracking (confidence<1), then basically DR using your last good heading. If you had held a good track before loosing the light, it would safe to assume you could keep going that way (for a while, anyway).
Hope this helps
Jon Mittelman
Programming Mentor
Team 236
TechnoTicks
Unread 13-02-2007, 16:04
Kevin Watson's Avatar
Kevin Watson Kevin Watson is offline
La Caņada High School
FRC #2429
Kevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond reputeKevin Watson has a reputation beyond repute
If I understand your problem correctly, you might consider mounting the camera at the rear of the 'bot.
-Kevin
Kevin Watson
Engineer at stealth-mode startup
http://kevin.org
Unread 13-02-2007, 16:26
FRC #1208
Hey thanks guys, what I was really looking for was more of a statement that would read something similar to if (tracking_state == CAMERA_ON_TARGET){...} because we are unable to move the camera without destroying it with innertubes and the arm that we're using. Because i'm uncertain as to what the states are, where they are located, and how i can use them to make sure that my code will only work while the camera is locked on.
Unread 14-02-2007, 13:04
EricS-Team180's Avatar
EricS-Team180 EricS-Team180 is offline
SPAM, the lunchmeat of superheroes!
AKA: Eric Schreffler
FRC #0180 (SPAM)
EricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond reputeEricS-Team180 has a reputation beyond repute
Take a look at the Get_Tracking_State function in Kevin's tracking.c I believe it has what you are looking for.
btw, our experience has been that you don't want to use the camera data for chassis commands until you get a CAMERA_ON_TARGET, and once you have a lock, don't ignore your camera until the tracking state has transitioned all the way to SEARCHING. (a bit of hysteresis seems helpful)
Don't PANIC!
S. P. A. M.
Edu Robot Camera Test Bed bear24rw Programming 7 06-08-2006 11:37
Robot Reset & Camera Initalization Don Reid Programming 3 06-03-2006 18:45
Camera Controlled Robot douglass1371 Programming 1 19-02-2006 19:22
Camera not working when connected to robot MarkVH Programming 5 14-02-2005 15:40
camera tracks but no movement from Robot Stillen Programming 4 04-02-2005 17:16
