Thread Tools |
Rating:
Display Modes |
Build your very own, VAN DE GRAAFF GENERATOR!
I found this fun site that has some cool sciency like home projects.
http://www.scitoys.com/scitoys/scito.../electro6.html The one I found the best, a Van de Graaff Generator! What is a Van de Graaff generator you ask? Well, basically, it is a static emitting device, that can be used to power lightbulbs, raise hair, or just to have some fun and shocking yourself (don't ramp them up to high, one of our mentor's friends built one, he cranked up the power, and touched it. He woke up 3 hours later across the room). You can buy one of these, a bit larger for around $500, but why buy something that you can build! I built one, but it only works when it feels like it (in otherwords, it's not that great) It's only my first, but my second will probably be better. These plans will only run you $15 to $25 (but this can increase if you plan on using an actual steel ball that you have to special order (this site just tells you to use a pop can) This only ran me around $15, but that's because I already had the motor for it. So, whacha think? |
Re: Build your very own, VAN DE GRAAFF GENERATOR!
We build a Van De Graaff generator last year, Our robot!
Neato!
instructables.com also has a ton of neat little electronic devices to build in your spare time. There's a project on there for setting up a control panel for your room's lighting with a special bulb that works in RGB, so you can customize the light of your room however you wish! |
| Build your own Arc Welder! | Adam Richards | Technical Discussion | 4 | 23-09-2006 16:22 |
| How-To: Build your own CNC machine | David Kelly | General Forum | 1 | 29-06-2006 23:34 |
| Building a van de graaf generator | Cuog | Technical Discussion | 8 | 05-06-2006 19:32 |
| How many of you build your own field? | Jessica Boucher | General Forum | 43 | 07-03-2006 21:15 |
| Build Your Own Robot Kit | Rich Wong | Robotics Education and Curriculum | 2 | 30-12-2002 20:50 |
