Go to Post "Oh, I get why we have Toy Story band-aids!!! The character Woody, and then in FIRST, we have Woodie Flowers. Woody = Woodie? I get it! I GET IT! - Millory [more]
Unread 13-02-2007, 18:28
Joe G.'s Avatar
Joe G. Joe G. is offline
Taking a few years (mostly) off
AKA: Josepher
no team (Formerly 1687, 5400)
Rookie Year: 2007
Joe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond repute
Send a message via AIM to Joe G.
Question Wiring an Elevator
Our robot has an elevator lift with a globe motor powered manipulator that could at any time during the match be anywhere from 3 inches to 8 1/2 feet off the ground. We need suggestions on how to wire this motor so that the wires can reach the highest point, but so that we also do not have random wires strewn all over the robot when it is at its lowest point.
Unread 13-02-2007, 18:34
rfolea's Avatar
rfolea rfolea is offline
AKA: Rick Folea
no team (Forsyth Alliance)
rfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant future
Re: Wiring an Elevator
Have you looked at the flexible conduit provided in the IGUS bag?
It's a great way to keep all those wires organized and IGUS will provide whatever you want for FREE.
Unread 14-02-2007, 00:01
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Joe,
A simple method is to attach surgical tubing at strategic places along the wire, so that as the elevator comes down, the tubing pulls the cable into a neat folded mass.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 14-02-2007, 00:16
Christian Christian is offline
FRC #0408 (RoboTicks)
Team Role: Leadership
Christian will become famous soon enoughChristian will become famous soon enough
Send a message via AIM to Christian
For our 2005 robot, we used an elevator design that had the same problem. The morning of competition, we went to Walgreens for stuff and found a retractable ID holders. Connect one end to the frame, the other to the bundle of wires. You will still have a bundle when it is low if you don't employ any other organization means, but it will be neat and out-of-the-way during travel and when it is higher.
President/Programming/Mechanical/Electrical/Animation/Website
robots and cake are all you need, everything else like oxygen are considered bonuses.
Unread 14-02-2007, 22:30
Pavan Dave's Avatar
Pavan Dave Pavan Dave is offline
Busy in College
AKA: I am John Gault.
FRC #1745 (P-51 Mustangs) FRC #118 (Robonauts)
Pavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond repute
Send a message via AIM to Pavan Dave
Here is something we used on our robot in 2005 is some sort of flexible cable cover that you can get at the following link. It works really well and it keeps your wire together. One suggestion is to measure your wires circumference before you buy it because if you have too much it could get caught in your lift so having the right size or close to the right size is very important. Also this stuff is expandable which makes it great for a tight fit but to cut it, i suggest you use a soldering iron because it frays if you use scissors, but besides that this stuff is the best and very easy to use.
http://www.crazypc.com/products/casemods/cablemng.htm
EDIT: If you do it right and pass the wire through the lift, your end effect will be something of this level. (The higher robot)
If you have any questions feel free to PM me.
Pavan.
Times change. People change. Teams change.
2008-Present: FRC1745, P51-Mustangs - Mentor
2005-2008: FRC118, Robonauts - Alumni
National Director of Philanthropy - Delta Epsilon Psi Fraternity, Inc.
1745 - 118 - ΔΕΨ
Unread 14-02-2007, 22:36
trilogism
Posts: n/a
We had the same problem with our lift.
All you need is all your wires, a piece of large diameter pvc, and a heat gun.
Coil the wires tightly around the pvc and tie it off, then heat with the heat gun for a couple minutes.
When you untie it and take it off the tube, the wires should act like a nice coil, and spring back together to the coil shape when the mechanism is lowered.
Unread 14-02-2007, 22:52
kmcclary's Avatar
kmcclary kmcclary is offline
Founder 830/1015;Mentor 66/470/1502
FRC #0470 (Alpha Omega Robotics)
Rookie Year: 1994
kmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond repute
I don't know the geometry of your lift, but one thing to consider is running the globe motor wiring through the center of a large bore diameter (1/2" or so) thinwall coiled plastic pneumatic tubing, to create a large diameter "coiled cord". (Be sure to use STRANDED wire, or it'll break!) This is available from most pneumatic supply sources. One end will eventually be anchored to the frame, and the other to the top segment.
For small footprint telescoping column towers, the tubing can be "helix'd" around the entire tower.
For larger, multi-vertical segment tower assemblies with cross braces (like "extension ladder" designs), you may need to use a horizontal stick off of the top segment to hold the upper end of the coil away from the tower's joints.
Running the wire through can be difficult, but can often be done via a "pilot line". First twist the wire pair carefully, to make a nice, even snake to run through the tubing. Note that twisting wire should always be in the OPPOSITE handedness of the strand's twist WITHIN the stranded wire, or it'll kink! You also need to insure the free end of each wire can freely rotate, as they'll need to spin as you twist the wires together.
Now take a thin but strong nylon fishline (or dental floss) attached to a paperwad, and use compressed air to shoot it through the coil. You then use this line to haul the twisted pair back through the coiled tubing (or to step up to a stronger line, and repeat).
The fit between the twisted pair wiring and the tubing's inner bore must be LOOSE or it'll jam partway through, so choose your coiled air line's inner diameter (and the wires to run through it) carefully. The wire gauge needed is defined in the rules, but a wire's insulation thickness often varies widely by wire vendor and/or product line. You'll need to have samples of the wire in hand when you go to find your tubing.
Does this description make sense?
Please let me know if you decide to use this technique! I've done it in the past on some other projects, but would like to see pics of your final config if you decide to use it on your bot. I hope this helped!
- Keith McClary
Chief Engineer, Team 1502 "Technical Difficulties"
Keith McClary - Organizer/Mentor/Sponsor - Ann Arbor MI area FIRST teams
ACTI - Automation Computer Technologies, Inc. (Sponsoring FIRST teams since 2001!)
MI Robot Club (Trainer) / GO-Tech Maker's Club / RepRap-Michigan) / SEMI CNC Club
"Certifiably Insane": Started FIVE FRC teams & many robot clubs (so far)!
2002: 830 "Rat Pack" | 2003-5;14: 1015;1076 "Pi Hi Samurai" | 2005-6: 1549 "Washtenuts"/"Fire Traxx"
2005-(on): 1502 "Technical Difficulties" | 2006-(on): FIRST Volunteer!
2009-(on): 470 "Alpha Omega" | WAFL | Sponsor & "Floating Engineer" for MI Dist 13 (Washtenaw Cnty)
2011: 3638 "Tigertrons" | 2013-(on): 4395 "ViBots" | 2014-(on) 66 "Grizzlies"
"Home" Teams: 66, 470, 1076, 1502, 4395
Local FIRST alumni at or coming to Ann Arbor (UM/EMU/WCC/Cleary)?
...We Want YOU as a Mentor! Please email me for info!
Support CDF Reputation - If a posting helped, thank 'em with rep points!
"It must be FRC build season when your spouse and children become 'Action Items 8 & 9'..."
Unread 14-02-2007, 23:42
Welle417 Welle417 is offline
FRC #1807
Welle417 is an unknown quantity at this point
Thumbs up Re: Wiring an Elevator
My Team has had the same problem, and we are also worried about light-duty wires being "guillotined" so to speak-haha ; Solution? McMaster Carr Catologue- coiled industrial wire any gauge in a rubber/insulated wrapping - works like a dream a peice 4 feet long stretched to almost 25 feet! :-D
-I also like the idea of the wrapping the wires around a pvc and heating them for a nice coil effect, but you might want to make sure you have a heavy duty wire to avoid severed connections :\ - Good Luck!
1807-One Goal, One Ambition, Multiple Minds
"And you never saw it coming..."
Unread 16-02-2007, 00:15
Dillon Compton Dillon Compton is offline
Jack-Of-All-Trades
FRC #1391 (Metal Moose)
Dillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud of
Send a message via AIM to Dillon Compton
In 2005 we dealt with a similar issue. We had a lot of luck using the "coiled" method (but with a minor twist). We were worried about weakening the wire by heating and coiling it, so instead we wrapped some extra pneumatic tubing around a piece of 2" PVC, and used a heatgun to make it coil (simply heat the coil evenly for perhaps 10 minutes, then let it cool and remove it from the pvc) . We then simply ziptied our wire runs onto the PVC with some light-strength, tiny zipties. Worked like a charm; no problems with connections breaking, and it looks pretty okay.
//Dillon Compton
Team 1394
www.metalmoose.com
pic: Israel regional crates elevator David55 Regional Competitions 2 28-03-2006 22:29
Elevator robots why didn't you.. Collmandoman General Forum 19 02-04-2005 17:17
Elevator Trouble: The Marta Ben Lauer Championship Event 26 29-04-2004 20:06
1418's Elevator Party? phrontist Chit-Chat 0 26-04-2004 03:03
Space Elevator Ian W. Chit-Chat 28 31-07-2002 14:04
