Go to Post Is there a way to spotlight an entire thread? - ctt956 [more]
Unread 14-02-2007, 21:52
Josh Murphy's Avatar
Josh Murphy Josh Murphy is offline
AKA: Josh
FRC #0051 (Wings of Fire)
Team Role: Coach
Josh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond repute
Re: CD 47 Edition 2007
Originally Posted by Henry_Mareck View Post
how much does your entire ramp system weigh?
One ramp assembly weighs roughly 16.5 lbs, so for both assemblies it weighs about 33 lbs.
-Josh Murphy-
Unread 16-02-2007, 00:07
WillItBlend's Avatar
WillItBlend WillItBlend is offline
Ctrl+Alt+De1337
AKA: German Khmelnitsky
FRC #0334 (Tech Engineers)
Team Role: Mechanical
Rookie Year: 2007
WillItBlend will become famous soon enoughWillItBlend will become famous soon enough
Send a message via AIM to WillItBlend
Looking good! We wanted to add ramps until we noticed our gigantic arm is in the way lol.
Unread 22-02-2007, 19:54
TheNotoriousKid's Avatar
TheNotoriousKid TheNotoriousKid is offline
AKA: Shane O
FRC #0025 (Raider Robotix)
TheNotoriousKid is just really niceTheNotoriousKid is just really niceTheNotoriousKid is just really niceTheNotoriousKid is just really niceTheNotoriousKid is just really nice
Send a message via AIM to TheNotoriousKid
that is a great ramp...simple...and looks easy to get on,,,,,,,,nice
Unread 22-02-2007, 22:40
AKA: Josh
Team Role: Coach
Thanks, Yes it is a very simple mechanism, and it is easy to get on.
-Josh Murphy-
Unread 23-02-2007, 07:47
petek's Avatar
petek petek is offline
What would Dave do?
AKA: Peter Kieselbach
FRC #3654 (Tech Tigers)
petek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond repute
Send a message via AIM to petek
Your ring grabber must be feeling pretty lonely with no one paying any attention to it, but I think it's pretty interesting. Is it automated, or does the driver have to run all the actuators separately?
Pete Kieselbach
Unread 23-02-2007, 08:21
AKA: Josh
Team Role: Coach
The driver does do all the driving. There are limit switches that help the driver out a little bit and there is a pot that we can view the value on the OI.
-Josh Murphy-
Unread 23-02-2007, 13:19
petek's Avatar
What would Dave do?
What motion/axis is the pot feedback for? I think using OI feedback is a good idea for troubleshooting, but do your drivers find it useful in competition, too?
Pete Kieselbach
Unread 23-02-2007, 13:26
AKA: Josh
Team Role: Coach
The pot feedback is for the position on the arm. It allows the programmers to put in dead zones, which are very helpful, and it allows us to know when we are in position to grab a tube. Plus we have what is called "Gas Mode" which is for the case that the programming goes bad or something for some reason, which allows the drivers have complete control and have no stops or any limits on any of the motions, so yes reading the pot is very useful to the drivers.
-Josh Murphy-
Unread 25-02-2007, 11:46
meaubry meaubry is offline
volunteer helper
FRC #6099 (Knights)
Rookie Year: 1997
meaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond repute
Hi Pete,
The ring grabber that you inquired about is pretty much automated, but the arm operator needs to coordinate opening the device with lowering the trolley.
The trolley is what allows the arm to move up and down a mast, as the motor walks up and down a chain. The bucket is hinged and opens and closes using a mechanism attached to a rack, which is driven by the window lift motor. At a specific point in the rack travel, the bucket is articulated open.
So, the arm operator simply locates overs the tube, and while lowering the trolley they push a button to drive the rack motor. While the tube pusher moves away from the tube, the bucket opens to clamp against the inside part of the tube. There is a switch to shut off the motor at the end of both the open and close travel positions.
The bucket also acts as a guide when aligning with the rack spider leg.
It didn't take the arm operator long to attain the skill to get really good at grabbing the tubes.
Mike
Unread 14-02-2007, 21:38
Andrew Blair's Avatar
Andrew Blair Andrew Blair is offline
SAE Formula is FIRST with Gasoline.
FRC #0306 (CRT)
Andrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond reputeAndrew Blair has a reputation beyond repute
Send a message via AIM to Andrew Blair Send a message via Yahoo to Andrew Blair
Originally Posted by Mike Martus View Post
Like most of the robot it is made of Alum tubing inc, the surface that is alum perf. Very thin, very light and very strong ( I hope).
We tested by using a 200+ pound person walking up and down the ramps ( a robot will never put that amount of force per sq inch).
Haha, except on entry...
What size hole, thickness, and alloy are you using? We're covering ours with 3/16" diameter hole, .05" thick, 3003 sheet from Mcmaster, with a similarly braced ramp. It feels good to me, but we'll find out I guess.
Reading makes a full man, conference a ready man, and writing an exact man.
-Sir Francis Bacon
"Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius -- and a lot of courage -- to move in the opposite direction."
-Albert Einstein
Unread 14-02-2007, 21:56
AKA: Josh
Team Role: Coach
Originally Posted by Mr MOE View Post
Mike:
Very nice! What is your ramp material made of?
Also adding to what Mr. Martus said, this is our practice robot so it looks shinier because we have polycarb under the perf metal, The competition robot does not. yep weight issues!!!
-Josh Murphy-
2007 Canadian kick-off Jan-6-2007 media coverage Mark Rozitis FIRST In the News... 3 07-01-2007 18:31
NASCAR '06 Edition Greg Perkins Chit-Chat 1 14-10-2006 17:23
Top 5- UTC edition Levin571 Regional Competitions 13 13-03-2006 22:46
FIRST College Edition? Nick Seidl General Forum 19 21-03-2003 12:39
