Go to Post Sloppy thinking leads to sloppy designs... - Joe Johnson [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 02-14-2007, 10:46 PM
Jack Jones Jack Jones is offline
Retired
Jack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond repute
Thumbs down BaneBot RS540 Motors Shorting Out:
What many of your are assuming to be failure due to stalling may be due to the motors shorting out. We had one shoot sparks and smoke. As could be expected, we assumed a hitch in the system might have stalled the motor. We later smelled the magic smoke, but didn’t associate it with the Banes, because we weren’t even running them. Finally, but not until a Victor gasped it’s last smoky breath, and another circuit sputtered and clicked, I’d had enough and proceeded with a second full continuity check. All appeared fine until I wiggled the RS540 leads – Bingo, zero resistance between +12v and the chassis. The other was the same – intermittent short!
Do not suppose the wires we’re tortured, or the connection was cooked – I did them myself.
BaneBots – how prophetic it that?
Unread 02-15-2007, 01:08 AM
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: BaneBot RS540 Motors Shorting Out:
Do you have any idea what caused the shorts? Had the motors been run hard enough to melt insulation, or is there just a mechanical problem with the terminal mounting? pics of what is shorted would be nice
Unread 02-15-2007, 05:10 AM
Retired
The motors had not been run hard; they had hardly been run - very gentile testing was all we had done.
It is definitely a mechanical problem with terminal mounting lugs. They wiggle in their plastic housing enough to cause an internal short. We are using them in a double-double rack and pinion lift for placing tubes. The motors move up and down with the racks. We used a similar system for Triple Play with FP motors and gearboxes - the FP terminals had no problems. But this year we're using our FP motors in our 6 motor 6WD, so we don't have the option of using anything but the 540.
We just discovered the source of the problem yesterday evening, and decided it'd be a good time to call it a day. Right now the plan is to find the happy place for those terminals and epoxy them in place. We're already using double strain relief to secure the wiring - but we'll take a look at making it better.
The bottom line is that our failure to notice the weakness of those terminals cost us one, maybe two, Victors. We hope that this post will prevent it from happening to sombody else.
Unread 02-15-2007, 09:02 AM
MrForbes's Avatar
AKA: Jim
Thanks for the heads-up!
I just ordered a few more of the RS540 motors, at $3.55 each it's worth it to be able to take one apart and learn more about them. We do have both FP motors unused, might be a good idea to see about installing a BB pinion on one....and also to make sure the RS540 motor wires are well supported, right now they're just hanging.
Unread 02-15-2007, 09:44 AM
MrForbes's Avatar
AKA: Jim
here are some pics of the brush holder and such of a Banebots RS540 motor.
(edit: added "before" picture)
ID:	5096  Click image for larger version
ID:	5097  Click image for larger version
Unread 02-15-2007, 07:19 PM
groves groves is offline
Steve Liggett
None #1213 (Groves)
Team Role: Teacher
groves is just really nicegroves is just really nicegroves is just really nicegroves is just really nicegroves is just really nice
Thumbs up ***FALSE ALARM***
***FALSE ALARM***
It must be getting late in the build season! The aluminum racks on our double rack and pinion gets shaved of by our titanium pinions. These shavings fell into awkward areas on our banebot system. Needless to say the electrical short that was happening was not the fault of the motor or bane bot, it was my own fault.
Thanks to squirrel for your sincere concern.
Unread 02-16-2007, 12:03 AM
MrForbes's Avatar
AKA: Jim
Glad to help...and a bit concerned about our own robot, which uses the 36mm banebots gearbox/RS540 motor.
I could not see any way that the terminals could short out, so having shavings in there is a reasonable explanation.
The programmers finally got the 1726 bot going today, the arm now works as it should, driven by that little 540 motor in a 125:1 gearbox, with a pretty well balanced gas spring holding it up. Several students took turns driving/scoring rings, and the motor seemed to work fine, although it did emit a little bit of "warm winding" odor. Should be ok....but we're working on setting up a FP motor on a spare gearbox just in case!
Unread 02-16-2007, 01:11 AM
redbarron's Avatar
redbarron redbarron is offline
Mike Barron
AKA: Mike
FRC #1270 (Red Dragons)
Team Role: Coach
redbarron is a splendid one to beholdredbarron is a splendid one to beholdredbarron is a splendid one to beholdredbarron is a splendid one to beholdredbarron is a splendid one to beholdredbarron is a splendid one to beholdredbarron is a splendid one to behold
Titanium Pinions?
The Red Dragons
2005 Buckeye Regional Woodie Flowers Regional Award
2005 Florida Regional Finalist Along with 1251 and 845
2006 Palmetto Regional Engineering Inspiration Award
2007 Florida Regional Judges Award and Regional Winners Along With 1251 and 86
2007 Curie Division Winner with 330 and 910
2008 Florida Regional Team Spirit Award Winners
Unread 02-16-2007, 11:04 AM
MrForbes's Avatar
AKA: Jim
Originally Posted by redbarron View Post
Titanium Pinions?
Must be one of those high-tech teams, we carved our pinions out of stone!
Banebot 2 motor adapter Ben Piecuch Motors 5 01-17-2007 04:06 PM
Banebot 64 to 1 on Spike? falconmaster Motors 7 01-15-2007 10:12 PM
Banebot Gearbox chris31 Technical Discussion 45 01-15-2007 05:56 PM
Motors out of sync TheAnsweris42 Motors 11 02-07-2006 04:30 PM
PWM and burning out motors patrickrd Technical Discussion 7 06-19-2003 03:30 PM
