Wiring Single Solenoid
How is the single soleniod wired? Our "inventory" guy lost the instructions..
Re: Wiring Single Solenoid
Do you mean the gray, flat solenoids? You should have gotten connectors that plug into the solenoid. Use those to connect the solenoid to a relay.
Yes, I mean the gray ones (festo), is the connector black?
We have wired our Solinoid correctly according to these directions, however it still will not switch which hole the air comes out of? Any ideas?
Our proggrammer insists that it is coded correctly. |
Does the light on the Spike change color when you hit the switch?
What colors do you see, orange and green? Does the light on the solenoid turn on and off as you hit the switch? The code should be (on the relay of your choice): Code:
relay1_fwd = 1; relay1_rev = 0; Code:
relay1_fwd - 0; relay1_rev = 0; Last edited by Mark McLeod : 18-01-2008 at 22:07. |
Yes the light on the spike change from orange to green.
Yes the light on the solenoid turns on and off. I can also feel movement inside the solenoid. I can't check the code now but will forward it to our programmer. Any other ideas? |
Try actuating the solenoid manually using the lever / pushbutton switch provided. If it works that way, then look at the programming.
It does work manually.
I guess that means it must be the programing? |
#10
you could also connect the leads to a battery and see if it switches state.
try it both ways to be sure. |
#11
At least 30 psi is required to operate the solenoid.
Double check that your air input is connected to the correct port (middle one on the side with three ports). |
#12
If the spike's LEDs change when you hit the switch, the programming is probably fine.
I would double check the operating psi (it needs to be at least 30 psi), and double check that the tubing is hooked up properly. When you say it doesn't work, can you feel air coming out one side of the solenoid, and it just doesn't switch sides, or is there no air at all? |
#13
We had the same problem in that we wired it correctly and the programming was correct and the tubing was correct. What we found was that the Fesco solenoid just didn't work. To test this, we pulled one from last year's robot and plugged it in. It worked fine. If you have another one, or a team near you has one, you might try swapping yours out as a test.
#14
Yeah what happened is they switched it out and went through about 2 more and found one that worked. I still wish I knew what was wrong...
#15
So do I. We have a Fesco that we can't use. We need to get another one.
| Festo Single solenoid | JP_1163 | Pneumatics | 4 | 24-02-2006 15:07 |
| Single vs double solenoid valve operation | Scott358 | Pneumatics | 0 | 29-01-2005 11:47 |
| Need instructions for SMC Single/Double solenoid | WHou | Pneumatics | 5 | 29-01-2005 08:17 |
| using single solenoid like a double | SteveO | Programming | 14 | 02-02-2004 22:51 |
| Single Solenoid Valve SMC | Chubtoad | Technical Discussion | 3 | 20-01-2002 15:16 |
