Go to Post It's ok to be tired. That's what CD Mods are for. - Jessica Boucher [more]
Unread 15-02-2007, 16:21
Oumonkey's Avatar
Oumonkey Oumonkey is offline
Master of the If statement
AKA: Josh Tyus
FRC #1555 (Pulse)
Oumonkey has a spectacular aura aboutOumonkey has a spectacular aura about
CMUcam communications with motors
Hello,
I'm not sure if I worded the title very well, but its the only way I can think to word it.
I'm currently working on a way to have the CMUcam to communicate with the normal motors from when the code tells the camera to move , from saying move +/- 1 for the motor to move until it centers. I am unsure if this will work very well. I read in the "Servo Values to Degrees... How?" thread talked about making degrees from the servo values, but I don't really understand it very well. So first I was hoping some one could help explain that to me, more of where to put what.
Also, I only want the camera working in auto mode. I have found a few things in around about it, although I haven't been able to do anything the past few days due to a bad snowstorm.
Another thing I want to discuss was what other teams are doing for auto mode, and how that are making the CMUcam communicate with other parts of their robot.
I'm not to sure if most of this makes since, and if it doesn't I'm sorry, I'm not feeling the best.
Thanks for the help
Josh 1555
Unread 15-02-2007, 18:07
Bharat Nain's Avatar
Bharat Nain Bharat Nain is offline
Bharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond reputeBharat Nain has a reputation beyond repute
Send a message via AIM to Bharat Nain Send a message via MSN to Bharat Nain
Re: CMUcam communications with motors
Well, if you want to use the camera to interact with the motors you are going to have to understand the code. It is not so complicated if you go through the comments. To start off, do not worry about camera.c/h. The file you really need to look at is tracking.h/c.
There are two ways you can use the camera to adjust your drive train to a specific point. Either you use the servo values when it is centered on the light, or you use the camera target values. There is no way I can go through exactly how to write this code, but good luck figuring it out. It is fun.
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 17-02-2007, 11:58
Oumonkey's Avatar
AKA: Josh Tyus
FRC #1555 (Pulse)
Well, I guess that didn't make much sense. Oh well.
I have the camera working perfectly. But I have a few problems with it communicating with the rest of the robot. I'm not sure if this would be the right place for this or not. But if I can avoid making a new thread, yay....
The robot, besides the camera, is not responding at all. I hooked up the dashboard and all pwms are 0 and pwm08, which isnt used, is 255. pwm04 to pwm 09 are not used also, but they are still 0. I am not sure if this is something electrical or not. The code I added is below. I am unable to test the code on any other robot right now. The battery is still giving power, the backup battery is still working. I haven't changed any other code besides user_rouintes.c and user_routines_fast.c. Right now i am thinking it is electrical, but I don't know.
Another thing I would like to ask is if the code below would work the way I want it to. It should be set so, if the cameras pan servo is more than 10 degrees it goes right and vice versa.
EDIT: I have just tested it again, I used a clean CMUcam s_21 and I put to lines of pwm16 = 140; and pwm15 = 114; And nothing still happens.
Thanks
Josh
1555
This code isn not copied and pasted from the original, so I may have miss typed something.
Code:
if ((((int)PAN_SERVO - 124) * 65)/124 > 10)
pwm16 = 140;
pwm15 = 114;
else if ((((int)PAN_SERVO - 124) * 65)/124 < -10)
pwm16 = 114;
pwm15 = 140;
else
pwm16 = 127;
pwm15 = 127;
CMUCam problems with EasyC Kickoff demo code Team 562 Programming 4 14-02-2007 14:27
Interrupts with CMUCam RyanW Programming 6 08-02-2007 23:32
Problem with TTL-RS232 + CMUCam Shinigami2057 Programming 6 28-01-2007 08:47
CMUCam with EasyC gabrielse Programming 5 01-02-2006 14:28
Problems with CMUcam & LABView Daniel_H LabView and Data Acquisition 1 30-01-2006 12:07
