Motors
Hey Guyz,
I just wanna Know wheather i can use Victors for both Mabochi (if i spelled that right) and Globe motors. Thank You Very Much Bilal Shahid Team 1219 |
Re: Motors
I'm pretty sure you not only can , but you have to.
David |
Re: Motors
That's not entirely correct. You do not have to, but you may.
Re: Motors
Thanks, for the correction.
The reason why I said that is because I remeber in a previews competition having a globe motor connected to a spike and the inspector made us change it to a speed controller. |
Re: Motors
There is no weight difference between a speed controller and a spike, however, and the speed controller gives you more flexibility. Eugene |
Re: Motors
That almost makes it sound like there's no reason to use a Spike. However, Spikes are "more flexible" in a different way -- Victors don't have two independent outputs. If what you need is on/off control, you can do it with half as much weight using a Spike than you can with Victors. A Spike also costs less and is not as prone to frying when accidentally abused.
Re: Motors
From Robot Rules Rev F
<R92> CIM motors and Fisher-Price motors must be connected to speed controllers. They can not be connected to relay modules. You can connect any other motor as you wish or design. |
| Motors, Motors, and More Motors | 1033missions | Motors | 1 | 09-02-2006 18:46 |
| Motors.. and more motors.. How many on your 2004 bot? | OneAngryDaisy | Motors | 33 | 23-02-2004 00:46 |
| Matching Drill Motors and Fischer-Price Motors | archiver | 2001 | 5 | 24-06-2002 00:51 |
| Fisher Price Motors for Drill Motors | archiver | 2001 | 0 | 24-06-2002 00:22 |
| F.P. Motors & gearbox for $12.50 Window Motors $19.50 | archiver | 2001 | 1 | 23-06-2002 23:05 |
