Go to Post To help keep the kids on top of their game, I remind them that the school board considers a grade of 97 an A , so we can lose 3% of the kids and still be considered excellent. - DonRotolo [more]
Unread 16-02-2007, 09:39
pagemauck pagemauck is offline
pagemauck is an unknown quantity at this point
Camera freezes
Our camera works perfectly - and then it doesn't. The first few minutes after powering up no problem - robot tracks light fine - and then green and red LEDS on the camera stay lit and the camera freezes. We've tried everything we've seen in the posts - checking PWM connectors - backup battery charge, resetting everything but no help. Generally the next day the camera will work again for its few minutes and then resort to frozen state. We are using Kevin's code.
I think I've read some folks with the same problems. Anyone fixed it?
I'm thinking we need a new camera - maybe we should try last years?
Thanks!
Unread 16-02-2007, 09:46
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Camera freezes
We've seen those symptoms when either the power or data connection to the camera gets a little loose. Try finding a way to secure the 3-pin cables to the connector so they can't wiggle.
Unread 16-02-2007, 10:47
EHaskins EHaskins is offline
Needs to change his user title.
AKA: Eric Haskins
no team (CARD #6 (SCOE))
EHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond reputeEHaskins has a reputation beyond repute
Send a message via MSN to EHaskins
Re: Camera freezes
I seen similar symptoms when I have a bad connection to the backup battery.
Try securing the three pin cables. If you don't want to remove the header on the board and solder the cable directly(I don't know if this is legal) then hot glue works good.
Eric Haskins KC9JVH
Unread 16-02-2007, 12:19
marccenter's Avatar
marccenter marccenter is offline
FRC #3548 (RoboRavens2)
Team Role: Coach
marccenter has a spectacular aura aboutmarccenter has a spectacular aura about
Talking Re: Camera freezes
I have read a number of messages on Chief Delphi
and have concluded the following about the camera
system. - power supply issues need resolution.
1) Add charger to 12V battery powering green
lights to ensure that the battery is fully charged
and enough power available to light green lights strongly
(not mentioned but I think a good idea).
2) Intermittment connections between moving pwm
cables and robot controller can cause camera resets.
Recommend solution 1) solder pwm cables to
camera board possible solution (legal?)
2) superglue pwm cable connectors
and add mechanical support (black electrical tape?)
3) 7.2 volt Ni-Cad battery cannot discharge below
7.0 volts without camera operation becoming flaky.
Solutions 1) Purchase extra 7.2 volt Ni-Cad for
competitions to insure fully charged battery available
More difficult 2) Build FIRST IFI charging circuit to charge
7.2 volt Ni-Cad circuit pack during competitions
Debug solution 3) Use regulated 8.0 volt power supply to camera during camera debugging to elimate this potential
issue.
Marc Center
FIRST FRC Mentor/Coach - Team 3548 Royal Oak RoboRavens#2 - on Sabbatical 2017 season
marc.center@gmail.com
Mobile: 248-255-7377
Unread 17-02-2007, 21:49
Re: Camera freezes
Thanks for the ideas. I think the power connection on the battery might have been suspect. We replaced them today and have not had a problem since.
Heck Freezes After The Thaw: Paperless Monopoly? Joe Matt Chit-Chat 11 30-07-2006 21:04
Heck Re-Freezes - Apple's Boot Camp Joe Matt Chit-Chat 19 06-04-2006 01:32
Camera Freezes? Athena Programming 8 06-03-2006 09:35
Heck Freezes Over - Apple Two Button Mouse Joe Matt Chit-Chat 11 03-08-2005 03:55
Heck Freezes Over: Windows 2000 & NT Source Code Leaked!?!? Joe Matt Chit-Chat 9 14-02-2004 21:14
