Go to Post Practice field Practice bot Iteration = awesome sauce - Akash Rastogi [more]
Unread 16-02-2007, 13:29
travmizer's Avatar
travmizer travmizer is offline
Head of Programming
AKA: Travis Schmidt
FRC #0617 (Springer Express)
travmizer is an unknown quantity at this point
Send a message via AIM to travmizer
Wink Makn' switches on a serial port
Ok:
We are trying to make our own switches to operate as the top, trigger and AUX buttons when we hook the up to port 3.
We stripped the wires, tried to figure out where they go (emphasis on TRIED), and now we need to connect the right wires to the right places on the switches.
The switches are simple, one way its a closed circit, the other way it's open
any help would be helpful
Isaac Asimov once said:
If knowledge can create problems, it is not through ignorance that we can solve them.
Unread 16-02-2007, 13:53
bcieslak
Posts: n/a
Re: Makn' switches on a serial port
go to the IFI web site
Go to the operator interface page and down load the
manual. I has all the pinouts for the connector.
BC
Unread 16-02-2007, 13:56
jdejoannis jdejoannis is offline
FRC #1845
jdejoannis will become famous soon enoughjdejoannis will become famous soon enough
What wires did you strip? the joystick?
The above mentioned pinout (which would be on IFI's website) will tell you which pins in the serial connector do what. You could make some sort of adapter.
Unread 16-02-2007, 13:58
MrForbes's Avatar
MrForbes MrForbes is online now
AKA: Jim
FRC #1726 (N.E.R.D.S.)
the way switches work is that they have a common, NO, and NC terminals. You probably need to connect the common and NO terminals to the joystick cable wiring.
On the internal joystick cable, the common wire is green, the trigger switch wire is black, and the top switch wire is brown.
at least that's what I figured out a couple days ago. Please double check with the pinout as suggest in the previous post, and look at this thread
http://www.chiefdelphi.com/forums/sh...ad.php?t=53472
also I don't quite understand why more people don't put the wire color in their otherwise very helpful joystick wiring diagrams
Unread 16-02-2007, 14:41
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Top is pin 7. Trigger is pin 2. Aux switch 1 is pin 10. Ground is on pins 4 and 12. The OI reference document from IFI tells you all this and more.
A switch is registered in the code as "pressed" (a value of 1) when the associated pin is connected to ground.
For your switches, connect the "common" contact to ground, and each of the "normally open" contacts to the proper pin.
Serial Port Help? StargateFan Programming 12 05-07-2006 14:06
Which Serial Port? crossedheart Programming 4 08-02-2006 11:35
TTL port to a serial port on a demo board ImmortalAres Programming 16 09-07-2005 23:44
No Serial Port Jeff Waegelin Programming 15 09-01-2003 22:29
More than 2 aux switches in 1 port f22flyboy Programming 2 01-11-2002 14:44
