Go to Post I don't know how you can blame a robot getting stuck in the goal on the GDC. The field drawings showed all of the dimensions of the goals. If a team doesn't want to risk getting stuck then they need to plan around it. - JamesBrown [more]
Unread 16-02-2007, 15:53
Guru's Avatar
Guru Guru is offline
Executive Programmer
FRC #0912 (Iron Lyons)
Guru is an unknown quantity at this point
Wire Schematic
The Schematic says that the red from the main power kill switch goes to the power distribution block, which then goes to the maxi breaker. Are we allowed to go from the power kill switch straight to the maxi?
\/\__Under Construction__/\/
Unread 16-02-2007, 16:18
AJ R's Avatar
AJ R AJ R is offline
RoboGeek
FRC #1714 (More Robotics)
AJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to behold
Re: Wire Schematic
No, the power distribution block must be used.
Also see http://www.chiefdelphi.com/forums/showthread.php?t=53437&highlight=power+distributio n+block
AJ
If you loose the match and the robot doesn't come back broken, you didn't drive hard enough.
FRC Electrical schematic Demothesis Control System 2 07-01-2007 13:31
Schematic Spica Control System 9 30-12-2006 13:00
Analog Joystick Schematic DonRotolo Control System 4 13-03-2005 22:06
Robot Electrical Schematic CHSguard72 Electrical 5 03-03-2003 21:30
drill gearbox schematic? Jeff Sharpe Technical Discussion 3 21-01-2003 00:18
