No camera data...
We hooked up the camera and we are using Kevin Watson's code, and when we try to run the program it shows "No camera data..."
Are there any suggestions that would help us??? James Penniston & Alex Rosenberg Last edited by D.Bear : 17-02-2007 at 15:14. |
Re: No camera data...
There's a number things to check:
1) The backup battery is fully chared at 7.2 volts. 2) The TTL and power cables are attached to the camera and to the RC. 3) You have the servos in the corrent pwm connectors. (Their defined in tracking.h) Right now our team is trying to fine tune the camera with our PID method before the robot ships tomorrow. :X Last edited by pheadxdll : 17-02-2007 at 18:57. |
Read the CMUcam workbook on Kevin Watson's site. If you've followed the directions to the letter and it still doesn't work, see the Camera FAQ:
http://www.kevin.org/frc/camera/ |
| Camera No Data | Lakeeffect1674 | Programming | 5 | 04-02-2007 12:19 |
| trasmitting data from a second camera | iwdu15 | Programming | 1 | 02-02-2007 19:25 |
| Question about default camera data table in easyC pro | itsme | Programming | 1 | 16-01-2007 13:57 |
| Camera Help (New to Camera Programming) | Idaman323 | Programming | 6 | 14-01-2006 03:56 |
