Backup Battery Charging Circuit
I have a question from the electrical team:
They built the custom circuit needed to charge the backup battery using the main 12V battery (found here). The output voltage to the RC is 8.8V instead of 7.2V. Is it still safe to connect the circuit to the RC? If not, what do you suggest we do? (we used the exact parts that are written in the diagram). BTW, the output to the battery is 9V instead of 8.7, so we assume that's OK. Thanks in advance, "Steampunk" #1577 electrical team |
| Back-up battery charging circuit from IFI | Don Wright | Electrical | 19 | 02-05-2006 20:41 |
| 571 Paragon Battery Charging Station | Rick | Technical Discussion | 7 | 27-05-2004 17:14 |
| Battery Charging Box | MikeDubreuil | Electrical | 17 | 22-04-2004 21:38 |
| charging backup battery | Max Lobovsky | Electrical | 6 | 12-03-2004 10:24 |
| Battery Charging - Warning! | sanddrag | Technical Discussion | 11 | 21-01-2004 00:10 |
