Problem with the Victors
We keep blowing Victors everytime we turn on our robot and use the joysticks. So far we have a box of Victors that have practically exploded when we attempt to drive. Is anyone else having this problem and does anyone know how we could possibly solve it?
Re: Problem with the Victors
I'm guessing you have your Victors connected improperly. Make absolutely sure that the + input is coming from a circuit breaker, the - input is going to a good negative "ground" point, and the M+ and M- pins are going to two sides of the same motor. Check for short circuits between the motor connections.
Ah, they were connected improperly. It turns out that our mechanic re-connected them the wrong way after we got the robot back from Kimberly-Clark. Thanks.
Heh, we have about $600 worth of Victors that we probably can't use now though =/ |
I suggest u hook them up to a battery and a multi-meter and check, our victors did that once and they work absolutely fine now
My suggestion would be to use a smaller circuit breaker, like a 20 amp instead of a 30 amp, and using a bigger wire size. The rules have the bar minimum wire size, we always try to go one bigger. Good luck, I hope you figure out the problem.
Dana,
You may be able to get them repaired by IFI for less than a replacement. Contact them to help you make a decision. |
are there any metal shavings that may have fallen into the victors? this would cause them to short.
i would suggest blowing them clean with compressed air and maybe even removing the fans for a more thorough cleaning. hopefully this is the problem and a simple solution. |
| Problem with the program downloaded to the controller | itsme | Programming | 9 | 14-01-2007 12:12 |
| Problem with the 2005 controller | Guy_E | Programming | 10 | 18-12-2006 01:38 |
| Problem with the battery charger | Lightposter | Electrical | 4 | 19-01-2006 10:39 |
| Problem with Lowering the Bar | Kevin Kolodziej | General Forum | 14 | 12-01-2004 21:58 |
| The problem with scouting... | archiver | 2001 | 10 | 23-06-2002 23:49 |
