Go to Post FIRST opened a door and I walked through it. - Erin Rapacki [more]
Unread 17-02-2007, 21:41
Banjo Banjo is offline
FRC #1835
Banjo is an unknown quantity at this point
Dual gyros
What's the easiest way to implement two gyros using Kevin's code? Would it be to modify every function to take an input for the gyro number (would take a while to do), copy and past/rename every function or is there a better way than these?
Thanks for the help
Unread 17-02-2007, 21:55
Cuog's Avatar
Cuog Cuog is offline
Registered Linux User: 390661
AKA: Alex
FRC #0422
Cuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond reputeCuog has a reputation beyond repute
Send a message via AIM to Cuog
Re: Dual gyros
You could copy his files over, and re implement with a different file name and change the names of the variables in them and the functions(actual you may be able to get away with not changing the variables but i don't know)
KK4KQO
http://voltair.us
Too many projects, too little time.
pic: 716 Dual Motor/Dual Speed CD47-Bot Robot Showcase 18 23-04-2004 01:51
White Paper Discuss: Dual-motor, dual-speed gearbox CD47-Bot Extra Discussion 8 05-04-2004 19:24
White Paper Discuss: Dual-motor, dual-speed drive transmission design CD47-Bot Extra Discussion 9 03-09-2003 10:40
Gyros!! RAWdealer59 Programming 1 12-02-2003 16:46
gyros archiver 2001 6 24-06-2002 02:35
