Go to Post I don't really care that the best on Curie may or may not be better than Newton, since we're going to spend the rest of the offseason discussing it no matter how the decision fell. - Jessica Boucher [more]
Unread 17-02-2007, 22:46
Nothing551 Nothing551 is offline
FRC #0333
Nothing551 is an unknown quantity at this point
Very Wierd Error
I get this error when I try to build an altered camera code
C:\MCC18\h\stdarg.h:6:Error: syntax error
Does anybody know what this means and can anybody help?
Unread 17-02-2007, 22:48
FRC #0333
Re: Very Wierd Error
Never Mind sorry for the trouble
I found out the problem.
Unread 18-02-2007, 15:54
Gaj Gaj is offline
FRC #0246
Gaj is an unknown quantity at this point
I just encountered the error -- how did you solve it?
Thank you!
Unread 18-02-2007, 16:05
Orborde Orborde is offline
FRC #1747
Orborde has a spectacular aura aboutOrborde has a spectacular aura about
Send a message via AIM to Orborde
Such errors that seem to show up in standard header files are because C is kind of dumb. Look just before where the header file got #included in your code. It's often something like this:
Code:
int some_global = 7   // no semicolon!
#include <stdio.h>    // but the error will probably be shown as being from this file
Unread 18-02-2007, 18:03
Gaj Gaj is offline
FRC #0246
Yup, that was it, thank you very much!
(As it turns out, there was a rogue 'z' at the very top of the file)
wierd compiling error Joohoo Programming 1 08-02-2007 21:32
Wierd search behavior.... Salik Syed Programming 7 23-02-2006 13:12
Very wierd compiling problem! Max Brin Programming 6 08-02-2006 15:43
Wierd error (With edu bot ... Salik Syed Programming 4 09-03-2004 21:34
Wierd basic init Jeremy J Programming 5 06-02-2003 11:42
