Go to Post Right now, it drives around....hopefully tomorrow it will do a LOT more! - MrForbes [more]
Unread 18-02-2007, 11:23
Asheron Asheron is offline
Asheron is an unknown quantity at this point
would this work?!?
Would this work or burn something out?
Using EasyC:
I have the same setup on both sides of the robot; a pump that heads out/in to lower a ramp on either side (so its actually 2 pumps, 1 on each side of robot)
Could I use the same button to lower each and raise each by doing the following
OIToRelay (3,1,2,1) //jostick on port 3 trigger button forward to relay 2
OIToRelay (3,2,2,2) //joystick on port 3 thumb button reverse to relay 2
OIToRelay (3,1,3,1) //jostick on port 3 trigger button forward to relay 3
OIToRelay (3,2,3,2) //joystick on port 3 thumb button reverse to relay 3
Would it cause problems trying to use the same input to control relay outputs???
Would the following work!?! Asheron Programming 2 19-02-2007 11:27
Designs that would never work... Cyberguy34000 Technical Discussion 60 09-01-2007 20:56
Would this mesh be legal? wun Rules/Strategy 3 21-02-2004 09:28
Would this balance? MattK General Forum 9 16-04-2003 20:11
I found this funny(who would do this?) E. The Kidd Chit-Chat 29 16-08-2002 16:03
