Go to Post A charged battery beats a dead battery any day. - Al Skierkiewicz [more]
Unread 18-02-2007, 23:53
meatmanek meatmanek is offline
Programmer/physicist/mathematician
FRC #0868 (TechHounds)
meatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to behold
Re: Encoder Problemo
The encoders need to be plugged into digital inputs 1 through 6. Those digital inputs are interrupt pins, and without interrupts, kevin's code doesn't work.
Unread 19-02-2007, 10:09
Seamus's Avatar
Seamus Seamus is offline
fattest man west of the equator
AKA: Fatman
FRC #1647 (Iron Devils)
Seamus is an unknown quantity at this point
Ithink that we are wired correctly
Do we have to call any function besides Encoder Initialization oroutside the readme?
Unread 19-02-2007, 10:23
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Wouldn't you rather be certain that the wiring is correct? If you tell us exactly how it's connected, we can tell you if there's something you misunderstood about the wiring and need to change to make it work.
Unread 19-02-2007, 13:03
Kingofl337's Avatar
Kingofl337 Kingofl337 is offline
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Rookie Year: 1998
Kingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond reputeKingofl337 has a reputation beyond repute
Send a message via Yahoo to Kingofl337
Here is a quick program I wipped up in easyC you can use to test your encoders.
Encoder 1 - Plug into I/O Port 1 (Channel A)
Plug into I/O Port 7 (Channel B)
Encoder 2 - Plug into I/O Port 2 (Channel A)
Plug into I/O Port 8 (Channel B)
Source:
Code:
void OperatorControl ( void )
      StartQuadEncoder ( 1 , 7 , 0 ) ;
      StartQuadEncoder ( 2 , 8 , 1 ) ;
      while ( 1 )
            PrintToScreen ( "Encoder 1: %5ld   Encoder 2: %5ld\n" , (long)GetQuadEncoder ( 1 , 7 ), (long)GetQuadEncoder ( 2 , 8 ) ) ;
Attached is pre compliled program incase you don't have easyC installed. You can upload it to your robot with IFI loader.
FIRST Team 501 PowerKnights - Mentor
FIRST Team 40 Checkmate - Mentor Alum
FIRST Team 146 Blue Lightning - Alumni
Encoder Problems bjimster1 Programming 2 10-02-2007 08:04
Encoder Error Anime-niac_2.9 Programming 1 27-01-2007 16:23
Encoder Problem DustinB_3 Programming 22 03-01-2007 20:42
Encoder help Windward Programming 21 14-01-2006 15:10
encoder.c Gary Bonner Programming 2 14-01-2005 13:41
