Quick EEPROM Question
I know that the EEPROM retains memory values while the RC is off, but does it retain memory when you re-program the RC?
Re: Quick EEPROM Question
Yes. If you need to clear it, use the EEPROM Wipe .hex file in Kevin's EEPROM code.
I tend to avoid using the EEPROM in a competition setting, though, as it can tie your robot's behavior to something that happened in the last match, etc. Last edited by gnirts : 18-02-2007 at 16:09. |
-Kevin |
| quick c question | shobuda999 | Programming | 6 | 22-02-2005 13:51 |
| Quick Question | Burgabot | Programming | 31 | 02-12-2003 19:22 |
| Quick <hr> question | Jack | Website Design/Showcase | 1 | 31-01-2003 22:19 |
| a quick question | mike pawlak | Championship Event | 6 | 02-05-2002 21:15 |
| A quick question | Joelster | Technical Discussion | 6 | 10-02-2002 09:09 |
