Go to Post They call us super nerds. I say thank you :D - Gregor [more]
Unread 18-02-2007, 16:03
Cody Carey's Avatar
Cody Carey Cody Carey is offline
AKA: C. Carey
FRC #0306 (CRT)
Cody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond repute
Send a message via AIM to Cody Carey Send a message via Yahoo to Cody Carey
User Code Critique
Hello everyone, I was just cleaning up the user code for this years 'bot, but I did it in notepad... so I'm not completely up on the syntax. I looked over it the best I could, but I would like some help so that I don't have to debug it when I go in on Monday. I would also like to know If I am using "SetRelay" correctly, and if there is anything that is done just plain sloppy/ how to fix it. Any help would be GREATLY appreciated
Thank you,
-Cody C.
Code:
unsigned char check;
unsigned char topcheck;
\*---------------------------ramp control-------------------------------*/
if (p3_sw_top == 1 && topcheck == 0);            // Press top button, kick cylinder extends; press top button cylinder retracts
    SetRelay ( 2 , 1 ,0 ) ;
    topcheck==1;
else if (p3_sw_top == 1 && topcheck == 1);
    SetRelay ( 2 , 0 ,1 ) ;
    topcheck==0;
if (p3_sw_trig == 1 && check == 0);              // Press trigger... Hippo folds down and ramp folds out; Press again, reset.
    SetRelay ( 3 , 1 ,0 );
    SetRelay ( 4 , 0 , 1 );
    SetRelay ( 5 , 1 ) ;
    check==1;
else if (p3_sw_trig == 1 && check == 1);
    SetRelay ( 3 , 0 ,1 ) ;
    SetRelay ( 4 , 1 , 0 );
    SetRelay ( 5 , 0 ) ;
    check==0;
/*----------------------------Arm control------------------------------------*/
if (p4_sw_aux1 == 1);                 // if top red switch is up, Hippo is up and Jaw is closed
    SetRelay ( 4 , 1 , 0 ) ;
    SetRelay ( 5 , 1 )
if (p4_sw_aux1 == 0);                // if top red switch is down, Hippo is down and Jaw is open
    SetRelay ( 4 , 0 , 1 ) ;
    SetRelay ( 5 , 0 )
if (p4_sw_aux2 == 1);                // if bottom red switch is up, Hippo is down and Jaw is closed (ramp down)
    SetRelay ( 5 , 1 )
/*-------------------------Shifting-------------------------------------------*/
if (p4_sw_top == 0 && p3_sw_trig == 0);        // if shifter is in Bottom position, servos are in position 1
    pwm05=0;
if (p4_sw_top == 1 && p3_sw_trig == 0);        // if shifter is in Middle position, servos are in position 2
    pwm05=127;
if (p4_sw_top == 1 && p3_sw_trig == 1);        // if shifter is in Top position, servos are in position 3
    pwm05=255;
Trouble using Kevin Watson's Serial Code with Vex user API StargateFan Programming 3 13-01-2007 15:42
Critique this code Ben Englert Programming 12 06-04-2006 01:21
New IFI Default/User and Master Code Alex698 Programming 6 28-02-2006 23:04
Critique Mike Website Design/Showcase 5 18-06-2005 02:15
user code to default code phoenixomega001 Programming 5 09-01-2005 00:09
