Go to Post I want an inflatable playing field so 2 people can setup the competition in one hour at every event. I want it to fit in the back of my car. - Ken Leung [more]
Unread 18-02-2007, 17:33
wingnut1705's Avatar
wingnut1705 wingnut1705 is offline
AKA: Kevin
FRC #0453 (Gears)
wingnut1705 is an unknown quantity at this point
Send a message via AIM to wingnut1705
Tracking only one Light
Our team wants us to only track one light instead of two. Does anyone know how to alter Kevin Watson's code so that the camera only tracks one light?
Unread 18-02-2007, 23:05
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Tracking only one Light
Someone else on the forum recently suggested having it use one of the bounding box corner values instead of the centroid values. You can pick a left or right corner and end up consistently tracking a single light.
Unread 18-02-2007, 23:18
efoote868 efoote868 is offline
foote stepped in
AKA: E. Foote
FRC #0868
efoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond repute
I believe you could also change your minimum confidence value.
Be Healthy. Never Stop Learning. Say It Like It Is. Own It.
Like our values? Flexware Innovation is looking for Automation Engineers. Check us out!
Unread 18-02-2007, 23:35
ace123's Avatar
ace123 ace123 is offline
AKA: Patrick Horn
FRC #0008 (Paly Robotics - http://robotics.paly.net/)
ace123 has a spectacular aura aboutace123 has a spectacular aura about
Send a message via AIM to ace123
The way the example code does it is by taking the leftmost coordinate (x0) and adding a constant to it. This way it ignores the median value of the box.
Code:
int lowright_x = packet.x1, centroid_x = packet.mx, upleft_x = packet.x0, target_width=packet.x1-packet.x0;
if ( target_width > WIDEST_ONE_LIGHT  ) { // looking at two lights?
    targets = 2;
    if ( ( lowright_x - centroid_x) < (centroid_x - upleft_x) ) {
        // the centroid is nearer the right
        target_x = lowright_x- HALF_LIGHT_WIDTH  ;
    } else {
        // the centroid is nearer the left
        target_x = upleft_x + HALF_LIGHT_WIDTH  ;
} else { // the target is NOT wide, it's one light
    targets = 1;
    target_x = centroid_x; // target that light
-Patrick Horn, Paly Robotics
Check out the space simulator called Vega Strike, modelled after the space simulator games Elite and Wing Commander. It's Open Source too!
If you have ever played Wing Commander, or especially Privateer, and had a feeling of nostalga derived from the you will enjoy these two Vega Strike mods: Privateer Gemini Gold and Privateer Remake!
I'm working on adding multiplayer support this year...
Multiple Light Tracking with Distinct Light Boxes in EasyC hal Programming 1 19-02-2007 11:56
Multiple Light Tracking with Distinct Light Boxes MaHaGoN Programming 30 19-02-2007 10:46
Enabling Multiple Light Tracking Using Kevin's Code Mitch Programming 7 05-02-2007 06:17
Light Tracking theycallhimtom Programming 1 19-01-2007 15:11
Camera Only Tracking Green sybert1ger Programming 2 08-02-2005 20:21
