Go to Post probably another ingenious game hint planted by Dave months before anyone even thinks about a game hint! - skimoose [more]
Unread 18-02-2007, 20:54
Bochek's Avatar
Bochek Bochek is offline
AKA: Adam Bochek
FRC #2200 (MMRambotics)
Rookie Year: 2007
Bochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud of
Problem with only 2 days left
Ok here is the issue, we have a arm that rotates, there is a potentiometer attached to one end and the arm is actuated via 2 fisher price motors and their 125 to 1 gear boxes (the white plastic ones)
i am attempting to get the arm to "servo" so that it stays upright most of the time, (a little bit of play is okay)
im running into a problem where the arm is shaking violently back and forth
i have placed a dead band in the code to try and stop this but the arms momentum Carry's it right past the dead band.
the motors are running off victors and i have them set about as low as they go.
any ideas is greatly appreciated
- Bochek
Adam Bochek - FRC 2200
http://www.mmrambotics.com
http://www.watchfirstnow.com
Unread 18-02-2007, 23:12
woody's Avatar
woody woody is offline
Too much metal for one hand! \m/
FRC #0033 (Killer Bees)
woody is a splendid one to beholdwoody is a splendid one to beholdwoody is a splendid one to beholdwoody is a splendid one to beholdwoody is a splendid one to beholdwoody is a splendid one to beholdwoody is a splendid one to behold
Re: Problem with only 2 days left
You may want to look into PID control:
http://www.chiefdelphi.com/forums/sh...light=pid+code
http://www.chiefdelphi.com/media/papers/1823
Also, just out of curiosity, are your victors running in "Brake" mode? That may help alleviate your problem by actually trying to stop the motors when they reach the right position instead of just cutting the power and letting them coast.
Good luck
"The greatest of all mistakes is to do nothing because you can only do a little; do what you can." - Sir Sidney Smith
Unread 18-02-2007, 23:40
ace123's Avatar
ace123 ace123 is offline
AKA: Patrick Horn
FRC #0008 (Paly Robotics - http://robotics.paly.net/)
ace123 has a spectacular aura aboutace123 has a spectacular aura about
Send a message via AIM to ace123
Are you using a printf to print out the outputs and variables every step of the way?
Most likely your code has some output value that's going too high and getting maxed out. You might be able to divide some things by a number (in PID, you want to reduce the proportional and the integral components)
-Patrick Horn, Paly Robotics
Check out the space simulator called Vega Strike, modelled after the space simulator games Elite and Wing Commander. It's Open Source too!
If you have ever played Wing Commander, or especially Privateer, and had a feeling of nostalga derived from the you will enjoy these two Vega Strike mods: Privateer Gemini Gold and Privateer Remake!
I'm working on adding multiplayer support this year...
Unread 19-02-2007, 00:05
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
you might also try setting one limit in the up direction and another in the down position - that can keep the control from hunting for the perfect spot.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
10 Days Left NERDS Andy Grady General Forum 13 20-07-2005 14:46
Anyone Know What This Means ? Help, only a few days left.. gemccnp Programming 4 19-02-2005 01:28
problem with joystick buttons (top left one) Richomundo Programming 5 15-02-2004 17:16
Only 58 Regional spots left... Aidan F. Browne Regional Competitions 17 14-11-2003 23:47
Seniors... how many days left? Jeff Waegelin Chit-Chat 16 02-05-2003 22:21
