Go to Post The part I like best is your method of transfering the torque via the balls. Very elegant. - Joe Johnson [more]
Unread 18-02-2007, 22:02
ggoldman's Avatar
ggoldman ggoldman is offline
FRC #0401
ggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud of
Send a message via AIM to ggoldman
pic: Team 401 - Render B
Unread 18-02-2007, 22:03
ggoldman's Avatar
FRC #0401
Re: pic: Team 401 - Render B
We just did a measure on the real robot. Our ramp gives 76" of real-estate for the end game. Our ramp is 36" wide and is 12" tall for the whole 76" with the lifters delpoyed.
Gabriel Goldman
PhD Candidate
RoMeLa: Robotics and Mechanisms Laboratory
http://www.me.vt.edu/romela
Virginia Tech
Unread 18-02-2007, 22:19
Crebb's Avatar
Crebb Crebb is offline
AKA: James M.
FRC #5279 (Bionic Eagles)
Crebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud of
384 looks forward to parking on you at VCU
Shibuya Hoppmann, Mechanical Engineer
VCU School of Engineering 2012
Team 5279 2016-Present
Team 384 2003-2015
Unread 18-02-2007, 22:24
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
Mecanums with a lifterbot?
Any reason why you'd rather have maneuverablility than strength? Unless there's an arm not shown, what advantage do you get from having mecanum wheels with a liftbot?
Originally Posted by Koko Ed View Post
The sign applause was definately one of the best moments I had ever witnessed at a FIRST event.
Who knew silence could be so loud?
Mayhem in Merrimack hosts: 2005-2016 - Week Zero hosts in partnership with FIRST HQ: 2014-2016
Unread 18-02-2007, 22:33
Lil' Lavery Lil' Lavery is offline
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Lil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond repute
Send a message via AIM to Lil' Lavery
If I am correct, there is an arm not shown. They have alluded to it in other threads, and he said this CAD was the "Inventor Rendering of Ramp/Truss Ready for End Game."
Being correct doesn't mean you don't have to explain yourself.
Unread 18-02-2007, 23:00
Crebb's Avatar
AKA: James M.
Is it just me or is there an arm built in to the ramp? That sure does look like a sprocket and arm mechamism in between the two ramp halves.
Team 384 2003-2015
Unread 18-02-2007, 23:02
Dan Zollman's Avatar
Dan Zollman Dan Zollman is offline
7
FRC #1712 (Dawgma)
Dan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond repute
How did you model the mesh ramp surface?
Product design student at Rensselaer
Web designer/consultant
FIRST alum, Dawgma 1712
dan.zollman - at - gmail.com
Unread 19-02-2007, 01:34
ggoldman's Avatar
FRC #0401
The arm IS shown. This configuration is for the "End Game" The arm tucks back into the robot (it is affixed to to end of the truss).
Gabriel Goldman
PhD Candidate
Virginia Tech
Unread 19-02-2007, 08:41
geeknerd99's Avatar
geeknerd99 geeknerd99 is offline
Fire Hazard
AKA: Daniel Lin
FRC #0401 (Hokie Guard)
geeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud of
Send a message via AIM to geeknerd99 Send a message via MSN to geeknerd99 Send a message via Yahoo to geeknerd99
Hey Gabe, where are the pistons???
(Hopefully Gabe doesn't mind, I think it's been revealed already)
We have two 2-bore pistons that retract, and through some sort of linkage, raise the ramp up. The linkage becomes stable at the top of its travel, so one bot can part on the flat part and the other gets lifted a foot into the air while on the ramp.
Now if you'll excuse me, I need to get to the shop ASAP. I overslept... again.
pic: Team 401 - Teaser #2 ggoldman Robot Showcase 7 12-02-2007 00:37
pic: Team 401 - Teaser # 1 ggoldman Robot Showcase 1 11-02-2007 01:41
TEAM 401: Scoring Arm Prototype - Point of View ggoldman Robot Showcase 15 30-01-2007 16:02
pic: 1083 Render CD47-Bot Robot Showcase 9 19-02-2004 19:00
TEam 401 contact info Andrew Rudolph General Forum 1 17-05-2002 00:24
