Go to Post you know your team has respect from teachers when classes start waving projects during build season saying you get full credit if the robot ships. - Peck [more]
Unread 19-02-2007, 13:05
Tz0m Tz0m is offline
FRC #0333
Tz0m is an unknown quantity at this point
Motor and camera pwms
Our motors are mapped to pwms 13, 14, 15, and 16. Our pan and tilt servos for the camera are mapped to pwms 1, and 2. For some reason, when we upload the camera code with Default_Routine();, appearing in user_routines.c, commented out, the camera works fine but we are not able to drive the robot and get no output from our joysticks. With Default_Routine(); uncommented, the camera does not work but we are able to drive the robot and get output from the joystick. A few times our joystick wound up controlling the camera's servos, but I don't remember how we had our code setup that time. Any help is greatly appreciated.
Unread 19-02-2007, 13:32
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Motor and camera pwms
Read Default_Routine() and look at what it does. You'll have to modify it to avoid messing with the pwm outputs the camera tracking code is using. The easiest way to do that in your specific case is probably to comment out the two lines that set pwm01 and pwm02.
Unread 19-02-2007, 16:51
FRC #0333
Thank you, this fixed our problem. However, we have the trigger on the joystick set to initiate autonomous mode, just for testing. When we press the trigger, though, the camera resets to the default position and then retracks the target.
Unread 19-02-2007, 22:39
Software Architect
Notice how User_Autonomous_Code() sets all the pwm outputs to 127 when it starts, including pwm01 and pwm02? You'll have to fix that if you want it not to interfere with the camera servos.
Unread 20-02-2007, 12:48
FRC #0333
Camera to motor setup Windward Programming 24 18-02-2006 20:29
Direct Control of PWMs and OI in WPILib CyberWolf_22 Programming 7 06-02-2006 19:06
pwms 13 and 15 in autonomous mode Chris Bright Programming 1 24-02-2004 22:25
External metal jacket on the Drill motor and FP motor, WHY? archiver 2001 3 24-06-2002 04:22
External metal jacket on the Drill motor and FP motor, WHY? Dennis Hughes Technical Discussion 1 04-06-2001 11:59
