Re: ramp tractions
Sorry, I meant to refer to adhesive tapes. Seeing as this is what most teams are talking about using, I was generalizing it.
Re: ramp tractions
Another alternative is a spray-on rubber coating that's used to coat tool handles:
Plasti Dip It's available at Home Depot, Target, etc... It also works great on grippers for the ringers. |
Re: ramp tractions
Adhesive TAPE is not allowed. Adhesives ARE allowed. Regards, Mike |
Re: ramp tractions
thanks for the info
Re: ramp tractions
our team used VEX field parts and cut them up.
We just put on our ramps inside tires of a bike =]
Re: ramp tractions
You guys could always use skateboard griptape, its a big sheet of sandpaper with adhesive on the reverse side... that would work great
Re: ramp tractions
Remember if it's sold as an adhesive tape, it's not legal. If it is sold as a self-adhesive sheet (and not as a tape), the 2007 Q&A has ruled that legal (subject to the rest of the rules).
Re: ramp tractions
Can you use grip tape from skate boards? Is it legal?
#10
Re: ramp tractions
Well that's sold as a sheet and intended to be used that way...
so, according to the Q&A it seems legal. |
#11
Re: ramp tractions
Please read this entire thread for the full discussion.
The short answer (per FIRST Q&A Forum) is that anything sold as a "tape" - that is, the packaging calls it a tape (even if it is sold in sheets versus a long narrow length), is not legal. If an inspector questions it, you need to be able to show packaging that calls it something other than a tape. |
#12
We used the skateboard stuff and it's great.
#14
Re: ramp tractions
On our ramp we used latex polyurethane with the floor grit that you can buy at any Lowe’s store. We painted it on our ramps Thursday night and we had all the traction you would ever need.
We let the team next to ours in the pits borrow some for their ramps and then they proceeded to use it to beat us in a qualifying match! |
#15
Re: ramp tractions
Brings up an interesting thought - we have often in the past used a product (I'm sure it's sold as a tape) that we call booger tape (for obvious reasons if you have ever used it). You put it on a surface, then peel off the brown paper tape and leave the adhesive behind. Which part is the tape, the paper or the adhesive? I would say the paper, since you call it adhesive tape - that would be redundant if the tape was the adhesive. A tape implies to me a continuous length of something, like a tape measure, cassette tape, etc. not something sticky. |
| Ramp dimensions | Grovestand | General Forum | 7 | 13-01-2007 15:01 |
| Motor Ramp Up/Ramp Down Function | Tom Bottiglieri | Programming | 12 | 03-12-2006 23:31 |
| Ramp or No Ramp | Cyber Punk 234 | Rules/Strategy | 29 | 20-02-2006 18:42 |
| To ramp, or not to ramp? | phrontist | Rules/Strategy | 27 | 26-01-2006 17:56 |
| Ramp | archiver | 2000 | 5 | 24-06-2002 00:08 |
