Go to Post I personally need all the limbs and eyeballs I currently have, and I assume other feel the same way. - bfk [more]
Unread 19-02-2007, 19:16
Lavapicker's Avatar
Lavapicker Lavapicker is offline
FRC #1056 (Hot Rocks)
Lavapicker is just really niceLavapicker is just really niceLavapicker is just really niceLavapicker is just really nice
Programming "sleep" function
We need to move our arm in autonomous but can't figure out how to program in a delay to regulate how long the motor stays on for. How is everyone else doing this??
Unread 19-02-2007, 19:50
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Bongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond repute
Send a message via MSN to Bongle
Re: Programming "sleep" function
Declare a global int counter, or a static int counter.
Suppose your autonomous mode can be divided into stages, like:
Stage 1: Drive closer to rack
Stage 2: Use camera to detect rack
Stage 3: Drive to vision target
Stage 4: Position Arm
Stage 5: Place ringer
Inside your autonomous routine, have something like this:
if(counter >= 0 && counter < STAGE_ONE_END)
{ // actions to do in stage 1
else if(counter >= STAGE_ONE_END && counter < STAGE_TWO_END)
{ // actions to do in stage 2
else if(counter >= STAGE_TWO_END && counter < STAGE_THREE_END)
{ // actions to do in stage 3
... // more if statements
counter++;
The actual values of STAGE_ONE_END and so on would be determined experimentally. Or you could decide for exactly how long you want each stage to run, then take the cycle rate of the CPU (xx.x milliseconds) and determine how many iterations are equivalent to your desired time.
Unread 19-02-2007, 20:21
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
SuperBK is just really niceSuperBK is just really niceSuperBK is just really niceSuperBK is just really nice
Thumbs up Re: Programming "sleep" function
Use a counter. Its 26.2 ms for each time User_Autonomous_Code() is called.
Code:
#define STAGE_1 0
#define STAGE_2 1
#define STAGE_3 2
inside User_Autonomous_Code()
static stage;
int counter;
state = STAGE_1;
  while (autonomous_mode)   /* DO NOT CHANGE! */
switch (stage) { case STAGE_1: // turn motor on here counter = 0; stage = STAGE_2; break; case STAGE_2: ++counter; if (counter = 38) // 1 second { // turn motor off here stage = STAGE_3 } break; }
Brian K
Team 1225 Robotics Mentor
MOEmentum: FYI - Post-ship "So, May I Sleep Now?" Mr MOE General Forum 1 22-02-2006 00:54
"call of function without prototype" railerobotics Programming 7 21-01-2006 19:59
New NEMO White Papers! "Creating a Killer Packet" and "25 Ways to Sponsor" Jessica Boucher Team Organization 0 10-08-2005 10:55
I'm having difficulties locating the programming code "gift" Flynn Programming 3 09-01-2005 22:01
"Thunderbirds" Vs. "Team America" Which one will rule the box office? Elgin Clock Chit-Chat 3 07-09-2004 19:53
