To all those that are having problems with their team light--I know of something you might want to check!!
The "Solid State Relay" mentioned in the wiring diagram COULD be the wrong one. The part number and marking may appear to be the same, BUT if one looks closely at the relay, they will notice that the relay may be ment for AC current applications. I just recently found this out when I compared our relay to a neighboring team's relay, and found that it had different markings in the middle. (Thanks guys!) Anyway, just read over the relay carefully, and make sure it has DC on it somewhere. --Just something you might want to check if you are having diagnostic light problems. ![]() |
| Diagnostic Signal LED | Dung H Cao | Electrical | 13 | 08-02-2008 13:24 |
| diagnostic lights | Breeze | Electrical | 3 | 14-02-2007 20:36 |
| camera trouble,cant tell the green-light from regular white light | Nimmy | Programming | 26 | 14-01-2007 14:53 |
| Red/Blue Diagnostic LED | ChuckDickerson | Kit & Additional Hardware | 5 | 09-01-2007 00:19 |
| cmucam2 Diagnostic? | muy dificil | Programming | 0 | 11-11-2005 11:26 |
