Go to Post The obvious solution is to only allow the real world to have negative jade induction coefficients. - EricVanWyk [more]
Unread 19-02-2007, 20:04
Jake M Jake M is offline
void* Jake;
FRC #1178 (DURT)
Jake M has a spectacular aura aboutJake M has a spectacular aura about
EEPROM Problem
Using Kevin's code, according to tests, either the write or the read is failing. The return from a read operation is 0.
Code:
void Process_Data_From_Master_uP(void)
  static unsigned char i;
  Getdata(&rxdata);   /* Get fresh data from the master microprocessor. */
  /* Remote Program Loading */
  drt_prog_switch = !SW_PROG;
  Default_Routine();  /* Optional.  See below. */
  Generate_Pwms(pwm13,pwm14,pwm15,pwm16);
  EEPROM_Write_Handler();
  Putdata(&txdata);             /* DO NOT CHANGE! */
Code:
/* EEPROM Address Mapping */
#define EEP_ARM_POT_STOWED_LOW   0x0000
#define EEP_ARM_POT_STOWED_HIGH  0x0001
Code:
  ARM_POT_STOWED = EEPROM_Read(EEP_ARM_POT_STOWED_LOW);
  ARM_POT_STOWED += (unsigned int)EEPROM_Read(EEP_ARM_POT_STOWED_HIGH) << 8;
Code:
  if(need_eep_update)
    if(EEPROM_Queue_Free_Space() > 2)
      printf("Updating EEPROM\r\n");
      printf("ARM_POT_STOWED = %i\r\n", ARM_POT_STOWED);
      EEPROM_Write(EEP_ARM_POT_STOWED_LOW,  (byte)(ARM_POT_STOWED & 256));
      EEPROM_Write(EEP_ARM_POT_STOWED_HIGH, (byte)(ARM_POT_STOWED / 256));
      need_eep_update = 0;
Yes, ARM_POT_STOWED is a variable, not a #define, and it is not zero on the write. It is a two byte variable, thus, I split it up into two bytes for the EEPROM.
Need an answer as soon as possible. Thanks in advance.
Code:
void function(void)
  function();
EEPROM Code Kevin Watson Programming 31 12-01-2006 11:37
EEProm Ryan Cumings Programming 2 01-02-2005 12:47
EEPROM Problems devicenull Programming 8 27-01-2005 15:07
Problem with reading and writing EEPROM DKolberg Programming 4 16-03-2004 19:29
Saving Data to EEPROM Phil Roth Programming 28 27-03-2003 22:29
