Go to Post FIRST really truly is not about the robots, is it? - Barry Bonzack [more]
Unread 19-02-2007, 20:07
Team 849 Team 849 is offline
FRC #0849
Rookie Year: 2007
Team 849 is an unknown quantity at this point
Hinges & Crates
Can we use hinges on the shipping crate?
Unread 19-02-2007, 20:25
Nate Laverdure's Avatar
Nate Laverdure Nate Laverdure is online now
FRC #2363
Team Role: Coach
Rookie Year: 1999
Nate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond repute
Re: Hinges & Crates
There's no documentation on hinges, per say, but I think you'll be OK if you use them. 612 has has hinged sections on our crate for a while and so have many other teams. From the rule book:
Originally Posted by 2007 FIRST Manual, Robot Transportation Section
All Crates must:
1) Comply with the “Wood Materials Regulations Across U.S. Borders” section below if the crate ships into the U.S.
2) Loaded crate must weigh 400 pounds or less in order to avoid drayage overage charges
3) Be sturdily built to prevent damage to your equipment
4) *Use 3/8” or 1/2” plywood
5) *Use 3/8” or 1/2” Oriented Strand Board (OSB), a solid panel product of consistent quality with no laps, gaps, or voids.
6) *Medium density fiberboard (MDF) is Not recommended for crate building because the material makes crate construction too heavy, and MDF can be dangerous to use if the correct safety precautions are not taken. MDF contains a substance called urea formaldehyde, which may be released from the material through cutting and sanding and cause irritation to the eyes and lungs.
7) *Don’t use particleboard because it collects moisture that adds weight and may cause the crate to fall apart. Remember, your crate may be exposed to the elements
when loading and unloading trucks.
8) Ensure your crate construction can withstand stacking during transport
9) "Sit" on 2 pieces of 4" by 4" lumber, spaced at least 28" apart so it can be moved by a forklift.
10) Have a footprint no greater than 4' by 4' and be no taller than 5'10" (70") high. This maximum includes the 4" by 4" lumber mentioned above.
Unread 20-02-2007, 17:22
GMKlenklen's Avatar
GMKlenklen GMKlenklen is offline
The "Masonater"
AKA: George Mason Klenklen
FRC #2167 (MASMabots)
Team Role: Leadership
GMKlenklen is a name known to allGMKlenklen is a name known to allGMKlenklen is a name known to allGMKlenklen is a name known to allGMKlenklen is a name known to allGMKlenklen is a name known to all
Send a message via AIM to GMKlenklen Send a message via MSN to GMKlenklen Send a message via Yahoo to GMKlenklen
Re: Hinges & Crates
another popular way to do it is to use t-nuts and bolts to keep one face on. that way you don't have to deal with a door in the tight pit area.
Thank you,
formerGrand Master Klenklen
-of the MASMabots-
Hinges? Matt21q General Forum 1 27-01-2007 12:17
Crates Venkatesh Kit & Additional Hardware 5 16-04-2006 15:19
pic: The Bobcats 2001 & 2003 & Admirers CD47-Bot Robot Showcase 19 28-02-2004 12:36
Painting Hinges? Sscamatt General Forum 3 27-02-2004 05:53
crates ivanslost Rules/Strategy 1 12-02-2003 21:50
