Re: Robot Disabled, yet I can still actuate a Cylinder- HELP!
Your robot is wired illegally. Move the Spike to a relay output NOW (or as soon as you get your robot out of its crate at a competition). |
That would be your problem. As others have already pointed out, Spikes need to be on the relay outputs only. Digital I/Os are meant for inputs like sensors or benign outputs like LEDs.
Thanks all. I'm guessing that the compressor shouldn't be wired to the digital IO either... ? Limit switches OK? |
Limit switch good for Digital I/O.
Compressor bad for Digital I/O. What is the Spike output wiring going to the compressor? The compressor is not fond of being driven in reverse... |
Compressor runs forward correctly- we're careful like that....
We tested it in reverse for a few seconds, just to see what happens (we were hunting for a short circuit). It appears to have run properly...
| HELP NEEDED! Camera twitches while disabled | lkdjm | Programming | 5 | 19-02-2007 11:34 |
| Can we still go? | Michael Corsetto | Championship Event | 1 | 22-03-2006 06:23 |
| LEGO ‘engineers’ compete to help the disabled | Billfred | FIRST In the News... | 1 | 07-02-2005 13:45 |
| can i use any other custom cylinder | MAXbattlebot | Pneumatics | 2 | 19-01-2003 12:44 |
