Go to Post Hey Don, if the [Woody Flowers] award doesn't impress the non-FIRST friends and family, just tell them you have your own "inter-web thread" - tell them you are like a Chuck Norris on the internet!!! - ebarker [more]
Unread 21-02-2007, 23:28
Bochek's Avatar
Bochek Bochek is offline
AKA: Adam Bochek
FRC #2200 (MMRambotics)
Rookie Year: 2007
Bochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud of
Problems turning
Well we shipped the robot with 2 main problems, we are 5 lbs over weight, and the robot doesn't turn.
im working on a sollution to the weight problem, but i have a question about the turning problem.
if you watch this video:
http://video.google.ca/videoplay?doc...15467259458065
you can see that we have issues with turning, we have to take a run and then quickly reverse one side to get it to turn.
i was thinking as a simple and easy sollution would be to replace all 4 wheels with the omni wheels available from andymark. as well as premounting the wheels to aluminum sprockets from ifi robotics so that its a simple swap at the competition.
my questions are as follows:
will this help us turn?
what are the disadvantages?
how much weight can we expect to loose by swaping to the aluminum sprockets?
Thanks alot.
- Bochek
Adam Bochek - FRC 2200
http://www.mmrambotics.com
http://www.watchfirstnow.com
Unread 21-02-2007, 23:36
Cody Carey's Avatar
Cody Carey Cody Carey is offline
AKA: C. Carey
FRC #0306 (CRT)
Cody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond repute
Send a message via AIM to Cody Carey Send a message via Yahoo to Cody Carey
Re: Problems turning
Thanks alot.
- Bochek
Yes, it will help you turn, but you will get pushed sideways. A lot. A more cost-effective/easy solution would be to just switch out two wheels for omnis. The only thig is that you would pivot around the two wheels that still have sideways traction, but if you replace your back wheels, it will allow you to pivot around the front of your robot... which could be a huge advantage while positioning around a target such as a tube.You can reasonably expect to lose between a pound and two pounds by switching out the sprockets.
-Cody C
EDIT: Your drivers have learned to cope with the decreased ability to turn very well. Good job.
Unread 21-02-2007, 23:37
Jizvonius's Avatar
Jizvonius Jizvonius is offline
AKA: Jevawn Roberts
FRC #1002 (CircuitRunners)
Rookie Year: 1997
Jizvonius is just really niceJizvonius is just really niceJizvonius is just really niceJizvonius is just really nice
Send a message via AIM to Jizvonius
Omni wheels will make turning much easier. The major disadvantage to that system is that while you can turn yourself with less effort, so can everyone else.
I would suggest only changing out either the two front or back wheels with omnis. This way you can still turn easily, but you can resist a little pushing from another robot. Note that your turning center will shift towards the non-omni wheels in this case.
The sprocket weight thing can be calculated based upon the size of your sprocket and the densities of the metals. If your current sprockets have large hubs, the weight savings could be significant
Edit: so a lot of this repeats Cody's post, but the sprocket calculations still stand.
Jevawn Roberts
Georgia Tech Mechanical Engineering Senior
Co-Leader - GT FIRST
gtfirst@robojackets.org
1997-2007 w00t for robots!
108-132-408-832-1002
5 teams worth of head scratching
Unread 21-02-2007, 23:45
Lil' Lavery Lil' Lavery is offline
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Lil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond repute
Send a message via AIM to Lil' Lavery
The omni-wheel placement depends on where they want the center of rotation to be. If they wish to pivot around the front, place the omnis in the back. Vice versa for pivoting around the back. If they wish to pivot around the center (as well as reduce opposing robots ability to pivot them compared to other omni placements), the best solution would to be place the omni wheels on opposite corners of the drive.
Being correct doesn't mean you don't have to explain yourself.
Unread 21-02-2007, 23:57
Cody Carey's Avatar
AKA: C. Carey
FRC #0306 (CRT)
Since surface area has no bearing on friction, I would assume that this would be a bad Idea. By putting the two "sticky" wheels beside each other, you are reducing the amount that the wheel has to be pulled sideways when turning, and increasing the amount that it rolls along the turn. This decreases over all turning friction.
If you were to place them on opposite corners, it would do nothing to the amount that the sticky wheels have to be pulled sideways to follow the circle of your turning radius, and since One wheel has the same amount of friction as two, I wouldn't expect this to solve your problem at all.
Unread 22-02-2007, 00:03
Goldeye Goldeye is offline
AKA: Josh Hecht
FRC #0694 (Stuypulse)
Goldeye has a spectacular aura aboutGoldeye has a spectacular aura aboutGoldeye has a spectacular aura about
Send a message via AIM to Goldeye
One of the best solutions to turning difficulties is very often overlooked.
Lower you gear ratio, significantly
It gives your robot the force to turn against friction, and saves energy while doing it.
Also, you will probably find it makes the robot much more controllable anyway.
This is just a suggestion, and seeing as it doesn't help you with weight either, might not be the best solution.
Team 694
2005 Championship - Galileo Semifinalist
2005 New York - Regional Chairmans Award
2005 New York - Semifinalist (Thanks 1257,1340)
Unread 22-02-2007, 08:13
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
From experience with vex bots, it definitely improves turning. Also look at 494/70 last year.
Omni placement all depends on how you want your robot to drive and how you want your robot to react to defense.
Unread 22-02-2007, 21:54
meatmanek meatmanek is offline
Programmer/physicist/mathematician
FRC #0868 (TechHounds)
meatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to behold
Not true. One wheel with 60 pounds on it has the same amount of friction as 2 wheels with 30 pounds each. However, one can assume that the weight of the robot will be approximately equally distributed across the four wheels, or at least the weight on the omnis will be the same as the weight on the traction wheels. Therefore, the traction wheels have only half as much turning friction as they used to.
Another solution would be to move your wheels closer to the middle of your robot. This increases turning capacity without decreasing traction. However, it causes balance problems, as your wheel base is shorter. Add a few trick wheels or casters that hover just above the ground to fix this problem.
Unread 22-02-2007, 22:40
Cody Carey's Avatar
AKA: C. Carey
FRC #0306 (CRT)
Can someone please explain this to me mathematically? I still don't get it.
It takes less force to rotate a wheel along the diameter of the turning circle than to scrub it sideways along the same circle. With the omni wheels in the front (right picture),you are basically applying force tangentially to the circle which you turn on, and with the omni wheels on opposing corners, You are waisting a lot of your force going outward from the turning circle, and scrubbing both traction wheels sideways.
Is it just that having the omnis on opposite corners woud decrease the force required to turn the robot, but not as much as the omnis on front of back would do? A little help would be greatly appreciated.
Unread 22-02-2007, 23:01
Tom Bottiglieri Tom Bottiglieri is offline
FRC #0254 (The Cheesy Poofs)
Tom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond reputeTom Bottiglieri has a reputation beyond repute
Yes.
While the second scenario you illustrated will get you closer to a "zero friction" turn, it also changes your turning radius from dead center in the robot to inside of the axis between your back two wheels.
Putting the omni's in opposite corners still gives you the problem of turning scrub, but it will significantly reduce the problem as half of your total weight is being distrbuted along wheels which experience little to no axial frictional force. For most situations, this should be enough to kill the bouncing robot problem. This also allows you to keep your 0 degree turn radius, and keep a solid wheel on the ground on each side of the bot at all times.
So really, its all up to driver experience and preference. I have been told that drivers who like to use one stick drive will be much better on a "power slide" bot (omnis on same side) and drivers who prefer two stick will be much better with a 0 degree turn radius.
Unread 22-02-2007, 23:24
Bochek's Avatar
AKA: Adam Bochek
Rookie Year: 2007
well today we ordered 3 andy mark 6" omni wheels,
the reson for 3 was incase one breaks.
we will be replacing the 2 rear wheels with the onmi wheels.
does anyone know the difference in weight between the ifi aluminum sprokets and the steel KOP wheels?
- Bochek
Unread 23-02-2007, 01:02
Arefin Bari's Avatar
Arefin Bari Arefin Bari is offline
AKA: Ari
FRC #0108 (SigmaC@T)
Arefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond reputeArefin Bari has a reputation beyond repute
Send a message via ICQ to Arefin Bari Send a message via AIM to Arefin Bari Send a message via MSN to Arefin Bari Send a message via Yahoo to Arefin Bari
- Bochek
The KOP wheels weighs .8 lbs. I believe you were trying to ask about the sprocket that was provided in the kit. If you are wondering if it would help you lose weight when you switch those steel sprockets to aluminum ones, yes you are on the right track.
Also, you are already going to lose .6 lbs by planning on swtiching those kop wheels to AM omni wheels. Those AM omni wheels weigh 5 pounds.
If you need help figuring out how to lose more weight and if you have detailed/close up pictures of the robot, feel free to contact me. I will be more than happy to help you guys and give some suggestions.
Ben Piecuch Ben Piecuch is offline
Bengineer
Rookie Year: 2000
Ben Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond repute
Bochek,
You didn't tell us what your drivetrain consists of, and your video doesn't give us much insight into it either. However, based on a previous picture you posted of your kitbot, I'm going to assume that you're using the standard kitbot setup with 4 kit wheels, a single motor Banebot 56mm tranny, and 2wd.
Your problem comes with the fact that your robot requires more power to turn than the single motor setup provides. The kit wheels provide a lot of traction in both the lateral (front/back) and transverse (side) directions. You need to either:
a) increase the supplied turning force.
b) reduce the required turning force.
You can solve (a) by adding more power with more motors, or by reducing the gear ratio to reduce your speed and increase your torque. With your existing weight problem, adding more motors doesn't help your cause.
You can solve (b) by reducing the transverse friction in your wheels. Most teams accomplish this by adding one set of "omniwheels" to their drivetrain. For 2wd setups, you would add the omniwheels to the non-driven wheels. Andy-Mark makes a nice omni-wheel, but they are not the only ones on the market. There are cheaping and lighter alternatives, such as ones found at McMaster.com or Omniwheel.com You can also reduce your required turning force by reducing your wheelbase, or powering all 4 wheels.
There are several whitepapers, as well as numerous threads on this site that explain this problem in more detail. Some simple changes should be able to be made at your competition to have you up and running in no time. Best of luck,
BEN
Unread 22-02-2007, 07:24
Bochek's Avatar
AKA: Adam Bochek
Rookie Year: 2007
Originally Posted by Ben Piecuch View Post
Bochek,
sorry, the drivetrain is the banebots 56mm gearbox with a CIM and 4wd.
basically the standard kitbot chassis but with added sprokets and chain to make it 4wd.
so replacing the rear wheels with omni's could prove a good solution then?
and i would still keep it 4wd correct?
- Bochek
  #15   Spotlight this post!
Unread 22-02-2007, 07:36
Jimmy Nichols's Avatar
Jimmy Nichols Jimmy Nichols is offline
Mentor,QCR Planning
FRC #1038 (The Thunderhawks)
Jimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond repute
Send a message via Yahoo to Jimmy Nichols
Yes, that would keep it four wheel drive. My question is, how are you operating your bot. If you are running a single motor and gearbox, think about adding another and running it tank style, this makes turning much easier without purchasing the omni's. The only drawback would be your wheelbase, the larger the wheelbase on your 4WD system, then the harder it is to turn if with a tank drive system.
Turning 18... Astronouth7303 Chit-Chat 16 22-05-2006 09:29
Turning problems in Vex autonomous. jamesgecko Programming 3 09-03-2006 16:41
Turning problems, we need suggestions PLZ Oumonkey Technical Discussion 44 20-07-2005 12:21
Turning Trouble! Cadetdan General Forum 18 05-03-2005 08:55
Arm Turning (programming) Joelster Programming 4 13-02-2002 21:35
