Go to Post You can have any color robot you like, so long as it stays that color. So you shouldn't have to worry unless you have a chameleon bot. - Kevin Sevcik [more]
Unread 21-02-2007, 23:55
htwiz2002's Avatar
Happy Birthday! htwiz2002 htwiz2002 is offline
Htwizard
AKA: Anthony Takata Bawahawba
#1290
htwiz2002 will become famous soon enough
Question IFI> Prompt
Okay, well I have been wondering for some time now about the IFI> loader prompt that is seen during various times from the Controller.
It seems like the prompt is used in conjunction with the IFI loader app in some way, but I am not sure. It is also appearing when I do not have an OI connected.
A second part of this question is: How do I use a controller without an OI? Apparently this is impossible, but since the entire code is open to change, couldn't it be modified to just simply allow the program port access (so I can test if my terminal program is actually working or not).
Simply: How do I use the IFI> prompt and what can I tell it? and How would I go about enableing program port access (only?) even if the controller is not connected to the OI? I discovered that I had everything I needed for development but the OI (even had the joystick!). If there is nothing I can do, I would still like some info on IFI>
Thanks!
TsAuKpAeTrA (Anthony)
Unread 22-02-2007, 00:17
Astronouth7303's Avatar
Astronouth7303 Astronouth7303 is offline
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Astronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud ofAstronouth7303 has much to be proud of
Re: IFI> Prompt
  1. See http://www.chiefdelphi.com/forums/showthread.php?t=42436
  2. Set your team # to 0
Unread 22-02-2007, 11:47
htwiz2002's Avatar
Htwizard
#1290
Talking Re: IFI> Prompt
I have seen that thread, and posted on it as well.
Don't you need an OI to set the team number?
I just want info on what the IFI> prompt and how to utilize it.
Unread 22-02-2007, 12:32
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: IFI> Prompt
Search the forums for "programming protocol". There's a thread with pointers to what I think you want here (see especially posts #35 and #41).
IFI sprockets... brennerator Technical Discussion 1 14-01-2007 15:06
Which Prompt are you using? 114Klutz 3D Animation and Competition 0 10-01-2007 19:32
Autodesk Visualization Prompt RubyHawk 3D Animation and Competition 6 07-01-2007 16:48
IFI> ? Wynlyndd Programming 4 01-02-2006 21:17
Chairmans Award Prompt charanznable Chairman's Award 3 24-01-2006 20:40
