A small issue with our Mecanums
Durring testing before crating up(sadly our only day we were able to get the bot on the ground), we noticed an issue with our drive, when moving sideways, our front wheesls sweep out, esentially making us pivot around the rears, also turning is very poor. I apologize, I have no video of the tests to demonstrate, but I can provide any other information that might be needed. Thank you all in advance for any help you can provide my team.
our wheels are layed out as such (lines reprresent the rollers): /...............\ /...............\ /...............\ \.............../ \.............../ \.............../ Last edited by AGWSPilot : 22-02-2007 at 20:52. Reason: the wheels were on top of each other |
Re: A small issue with our Mecanums
Well i think you have your wheels backward...you need to swap the right and left i think...Talk to M. Krass. She knows a lot and is very helpful.
Is that diagram from the top or the bottom? From the top of the robot, the rollers should form an X, or looking up from the bottom they should form a diamond (<>).
Yes, your wheels are backwards. It should be like this
\.............../ \.............../ \.............../ /...............\ /...............\ /...............\ Last edited by DB_UPS : 22-02-2007 at 21:16. |
I will try to get a hold of M. Krass. |
Thank you all.
The rollers touching the ground should be able to roll toward and away from the center of the robot. If you can spin your robot in place without any of the wheels moving, you've got your wheels backwards.
It helps if you think of the wheels applying forces perpendicular to the axis of the rollers. when the rollers are arranged as you had them, the diagonals were applying forces in the same directions, which led to problems. You can either arrange the roller axis as an X across the bot, or an 'O' around the bot... not quite sure which one is better, as flipping the bot upside down will result in the other configuration.
Good luck ![]() |
Also it sounds like one side is outputing more power than the other.
Are you just setting PWMs or is there some feedback to control the speed? |
#13
Currently, we are just using PWM's. I tried in the code to reduce power to several different permutations of wheels, and it made little or no change to the behavior of the system(it still pivoted on the rear wheels), I don't think the problem lies in wheel speed. But thank you for the suggestion.
#14
If you can get some feedback happening you are going to be a lot happier with your handling, I think. We use shaft encoders to ensure the wheels are all turning at the correct speed to give us the motion we want, while I know of other teams who have reported success using the gyro to stabilize their heading.
If you've got the banebots encoders and divider cards on board, we've developed some code that might be able to help, which we are willing to share. Drop me a PM. If not, it is probably easier to just tack on a gyro... perhaps there is someone willing to share their techniques for gyro stabilization of a mecanum drive. To see some clips of how we move try http://www.youtube.com/watch?v=gyn9e0cT3-A Jason P.S. Some posts surrounding mecanum drives insist that you need a suspension to have a working mecanum drive system. While that may be true on a rough surface, we are quite satisfied with just having a bit of flex in the frame. |
#15
this may come too late to really help you, but by changing the wheels, you will have to flip your side-to-side controller, otherwise you will go right when you wanto to go left. all other driving functions (forwards, backwards, and spin) like regular tank drive, so it will ramain unaffected.
| Small Banebots Motor Issue - Lessened torque and smoke | sanddrag | Motors | 10 | 12-02-2007 21:41 |
| Issue with downloading code to the 2007 RC | thefro526 | Programming | 3 | 10-02-2007 17:26 |
| Issue with CMUCam2 Demo application | Bio | LabView and Data Acquisition | 12 | 21-01-2006 16:08 |
| Our Small Parts Experience, to all TEAMS | Anton Abaya | General Forum | 29 | 04-02-2002 15:52 |
