Go to Post I don't care what Dean, Dave, Woodie, or whoever says at kickoff--if it isn't in the rules, it isn't in the rules. - EricH [more]
Unread 22-02-2007, 22:13
AGWSPilot AGWSPilot is offline
FRC #1415
AGWSPilot is on a distinguished road
Re: A small issue with our Mecanums
Originally Posted by devaaki View Post
It helps if you think of the wheels applying forces perpendicular to the axis of the rollers. when the rollers are arranged as you had them, the diagonals were applying forces in the same directions, which led to problems. You can either arrange the roller axis as an X across the bot, or an 'O' around the bot... not quite sure which one is better, as flipping the bot upside down will result in the other configuration.
Good luck
I get what you are saying, this won't be the first year we have had to swap wheels at the regional, at least it isn't for a new set this time!
Small Banebots Motor Issue - Lessened torque and smoke sanddrag Motors 10 12-02-2007 21:41
Issue with downloading code to the 2007 RC thefro526 Programming 3 10-02-2007 17:26
Issue with CMUCam2 Demo application Bio LabView and Data Acquisition 12 21-01-2006 16:08
Our Small Parts Experience, to all TEAMS Anton Abaya General Forum 29 04-02-2002 15:52
